turquoisedude
It's been almost a year that I lept on the chance to save a matched 1958 Westinghouse washer/dryer (I had originally thought the washer was a 57 model, but it is a 58).  The washer needed lots of TLC - tub had fallen and was damaged in careless transit by even more careless movie production people, the machine needed a new rear tub bearing badly, and the pump, pump drive wheel/pulley, and water inlet solenoids have all been replaced.  When I run it now, it purrs like a kitten.  Everything should be fine, right?
Nope.
The issue I'm now up against is that the tub will stall with even a medium-size load of laundry. I have successfully run several tests with just a tub of water and all has been fine - the machine filled, washed, drained, and ramped up to spin. But just add laundry and....ooops.
I had noticed the issue last autumn, suspecting the tub height was at fault - not the case. I also tried changing belts but this has not helped at all (unless, of course, I messed up on the belt size...).
I've got the L110 manual and belt tension is the number one cause for the 'wash basket does not rotate' bugaboo, however there is no procedure/suggestion/incantion for adjusting belt tension. I've done this with my older Westy, the style with the speed changer, and there is fairly obvious adjusting spring and screw assembly on the speed changer unit.
Now, I mentioned that I changed the belt pulley/pump drive wheel - naturally I thought that perhaps I had not tightened the set screw for this properly (I have the strength of an 8-year-old) but it was good and tight.
Any suggestions as to how I might be able to tension the belt?? Oddly, there is also no mention of how much the belts should deflect in the L110 service book.
			Nope.
