What a fantastic community I have found
Whirlpool
Hi Folks,
Thanks for all the input on Voltage specs I am very surprised by the use of 3 phase in a domestic environment, only single phase is used in the UK for domestic supply.
Steve (SactoTeddyBear),
I will post a picture of the UK Hotpoint Drier later today I intended to do it yesterday but I got side tracked and forgot all about it. I have seen one example of the beige coloured version of my machine and a matching Drier they were a couple of years older than my machine but apart from the colour the washer was identical. I hope you are feeling better today? Did you get my e-mail OK?
Steve (toggleswitch),
Yes indeed the USA flag sticker is very cool and yes Whirlpool were indeed the World leaders in Laundry products at that time however I believe Electrolux Group of Sweden is currently the world’s largest appliance manufacturer.
You may find it interesting that Whirlpool first entered the European market when they took over the Dutch electronic giant Philips’s white goods division; the first line of products carried the brand Philips-Whirlpool after a year or so the Philips name was dropped and the products were branded Whirlpool.
Bob,
My Whirlpool Top Loader is six years old and thankfully has been totally reliable, it works and sounds the same today as when I first bought it. The Whirlpool Top Loader is my favourite washer.
Regards.
Hugh
Steve (SactoTeddyBear) this ones for you.
Hi Steve,
I finaly got round to it so here you go one UK Hotpoint Ultima Electronic Condenser Drier.
Regards.
Hugh.
Re: Thanks Hugh:
"OMG" Hugh, I was expecting the Dryer to look similar to our American Models. That is a great looking Hotpoint, where can I place an Order? {LOL}...What is the Black Disc-Like, with a White Circle around it, on the lower right of the Drum in the Photo? What is below the Drum opening, is this a Condensor Dry Machine? It also looks like the Door can be reversed, for Left/Right side of Washers. I like the Controls, they seem quite simple to understand and operate, for setting everything, as well as being quite flexible settings. Is the Drum Interior Stainless Steel?
Thank you so much for sharing the Pix of your Washer and Dryer. How old is your Dryer, it looks quite new?
Peace and Happy Wp/Hotpoint Washing and Drying, Steve
SactoTeddyBear...
Hi Steve,
Thanks for your kind comments; unfortunately this is not in the same league as an American Drier. Like most UK models it is designed to fit under a standard 600 millimetre work top so it only takes a 12Lbs load. The drum is made from Zinc Galvanised Steel and the disc you see is the moisture sensor it detects if the load has reached the dryness level you have selected; once the selected level is reached it switches off the heat to cool the laundry down this usually takes about 10 minutes, it then sounds a buzzer and switches to an anti crease cycle where it gives a short tumble every 2 minutes until you unload the drum.
Yes it is a condenser model; the thing you see under the drum opening is the heat exchanger or condenser unit, it pulls out so any accumulated fluff can be rinsed out easily.
The controls are very easy to use you simply select the fabric type and the degree of dryness then press the start button, the electronics automatically select high or low heat depending on the chosen fabric, the rest is fully automatic as described above. It is a fairly good drier but it does tend to roll large items like sheets into a ball as a result they don’t dry properly so I end up unrolling them and trying again. I purchased the Hotpoint Drier in January 2001 so it is 4 years old now and thankfully apart from its sheet rolling tendencies it has not let me down.
Sadly Hotpoint UK which was previously owned by GE is now owned by Indesit Company (Formerly known as Merloni Electro Domestico) so only time will tell what will happen to the the UKs best selling washer brand.
All the best.
Hugh.
Re: Hotpoint Dryer:
Hey! Hugh, thank you for the info on your Hotpoint Dryer. I kind of thought that the Round Black item might have been an Electronic Sensor. Are there more than 1-Sensor in the Drum?
The 1965 Lady-K Dryer had 3-Sensor Bands that ran around the inside part of the Drum, to feel the Moisture content in the Laundry. I've got one of those Dryers, at this time it is covered up outside and is going to need some "TLC" on the Cabinet, besides some underneath Mechanical "TLC" as well. Doesn't your Hotpoint Dryer do a Reverse Tumble, I thought that a lot of the Overseas Dryers did, even if they were Brands of American Companies?
The WP/Kenmore Dryers later on, when they came out with what they called "Wrinkle-Guard" the "TOL" Dryers had a 2 1/2 hour setting, with Air Only every 5-minutes, for about 15-seconds.
It sure is too bad that so many of the Major Companies are selling out and even merging with some of these "odd" companies, that are going to not have the longevity of operating as some of our Vintage Laundry Appliances are able to do still.
Peace and Happy WP Washing and Hotpoint Drying, Steve
SactoTeddyBear...
Hotpoint Dryer
Hi Steve,
No there is only that one sensor in the Hotpoint although you would think there would be more, it does reverse tumble but because it is a condenser dryer it tumbles more one way than the other and this causes the balling problem. I would not recommend this dryer to anyone because of the balling problem it is also extremely noisy with loud roaring fans.
Your 1965 Lady-K Dryer sounds like a nice machine you should do your best to get it running again, we need to keep these real machines alive and running well.
I agree it’s a sad situation with all the distinct brands being absorbed by the giants but that seems to be the way of the world these days.
Peach and happy restoring.
All the best.
Hugh
Re: Reverse Tumble:
Hi! Hugh, I've got an "LG" Compact Combo that does Reverse Tumble Washing and Drying and I believe that the Tumbling during the Dry Cycle is equal both ways. I've never Washed/Dried any Sheets in this Machine, but everything else seems to not get Tangled together, except for maybe a couple of Pant Legs once in a while, but everything else comes out separately, not tied together.
Peace and Happy WP & Hotpoint and "LG" Washing and Drying, Steve
SactoTeddyBear...
Reverse Tumble
Hi Steve,
It does reverse but the problem with the Hotpoint is that it tumbles more in one direction than the other. This seems be due to the design of the fans used in its air cooled condenser drying system, the fans are highly efficient in one direction but not so good when reverse tumbling so it tumbles 2 minutes in one direction and reverses for 30 seconds.
Peace and happy Lucky Goldstar drying.
Hugh.
Re: Thank You Again:
Hi! Hugh, thank you again for sharing all of your info and Pix of your wonderful Laundry Appliances and how they are similar but somewhat different from our American-Made Laundry Appliances. Please keep up the wonderful knowledge of sharing with us, along with any other info that you would like to share with us about the "UK" Appliances and differences.
Peace, Happy Whirlpool and Hotpoint Washing and Drying, Steve
SactoTeddyBear...
Your Welcome
Hi Steve,
You are very welcome, I am so pleased you fuond my machines interesting. Give me an American washer any day, I just can't stand the tiny drums and pathetic capacity of the vast majority of UK washers.
Peace and happy high capacity American washing.
All the best.
Hugh
