What Exactly Is "Moist Cool" Anyway?
launderess
Jul 22, 2004
20,858
Have seen in various adverts vintage and not so much makers of refrigerators touting "moist cool". Supposedly this kept foods fresher longer all without need for crisper drawers and or other closed off areas.
Only time see any sort of condensation in my GE fridge is during humid weather when have had door open too long, or going in and out.
Moist Cold ?
That is a very good question Launderess, some refs are differently more moist than others depending how the cooling system is designed, one would think that if a refrigerator manufacturer actually had a better system they would talk about what the humidity level is in their refrigerator.
My pantry all-refrigerator I modified so the inside fan runs all the time which causes the evaporator to defrost without a heated defrost cycle whenever the compressor shuts off, as a result the moisture stays very high. You can tell by cardboard boxes in the refrigerator because they are damp and soft compared to my other all-refrigerator., overall I can not tell any difference in food life although I did have some apples last over one year in the pantry ref.
Single-evaporator refrigerators, which recirculate cooled air from the freezer into the fresh food section, are by-and-large a low-humidity environment.  Moisture (frost) is continually collected (and drawn out of food) onto the cooling/freezing coil and then drained away via auto (or cyclic) defrost.
Freezer burn is dehydration.
Moist cool would be a design effort to provide higher humidity in all or some areas of the fresh food section.
Dual-evaporator refrigerators can do that better by way of having separate cooling coils in each section.  The refrigerator evaporator doesn't need to run as cold and gather so much moisture and defrost it away.  Sub Zero and such that have two compressors, completely separate refrigeration systems for the two sections, are touted as excelling at storage longevity of fruits and veggies.  Other designs (such as the GE Arctica that was included with my house) have one compressor with a valve that can send refrigerator to either the freezer coil, the fresh food coil, or both.
Moist cold was a term invented to describe a refrigerator environment that simulated the moist cold of an ice box which did not dry out foods because the block of ice that kept the fresh food compartment cold my melting at temperatures above freezing. Having an evaporator in a mechanical refrigerator that was the coldest part of the refrigerator/freezer naturally tended to pull all of the moisture out of the fresh food compartment and turned it into frost on the freezer coils. To counteract this drying, Frigidaire had sealed vegetable compartments called "Hydrators" because they were sealed from the cold, dry air of the fresh food department. Refrigerators with moist cold used various ways to add moisture to the air, but they all eventually had sealed high humidity compartments for fruits and vegetables.
Interesting....
Frigidaire had something they called "Cold Wall" refrigerators.
Apparently a "Dew Mist" glass seal seperated lower chamber from top (freezer?), and refrigeration coils were built into walls surrounding lower compartment. There you had it, a cold refrigerator without "moisture robbing", air circulation.
https://digital.libraries.ou.edu/sooner/articles/p21_1938v11n9_OCR.pdf
Tend to focus mostly on laundry appliances, but guess early on refrigerator makers were thinking up ways to lure hold outs from ice boxes to their products.
I wonder if 'Moist Cool' refers to a standard refrigerator... the type without a fan recirculation system?
My mum has a Tricity Bendix fridge-freezer (made by Electrolux/Zanussi), with a frost-free freezer (fan forced) and the refrigerator section also has fan forced air blowing through it. It seems to dry out fresh foods in the fridge compartment quite readily.
There were other versions from different manufacturers, where only the freezer section was fan forced frost-free; the fridge section had no air flow, just the standard cold wet wall, which periodically slightly frosted up and melted into a drainage channel.
Reading about the Frigidaire cold wall, was the secondary coil that ran through the fridge wall, just a fluid transfer from the primary cooling coil? From the diagrams I've found online, the Secondary coil doesnt seem to be connected to the compressor?
If I'm seeing that right, what an intriguing way to change the refrigerant temperature from the freezer to the fridge walls.
https://www.applianceblog.com/mainforums/threads/1939-frigidaire-cold-wall.66667/
That Frigidaire "cold wall" design sounds rather complicated and an accident waiting to happen. One puncture in wrong place and there went that fridge.
Still an interesting design concept for sure. Does anyone today make fridges with "cold wall" design? That is coils surrounding fresh food cabinet instead of blowing cold air.
Frigidaire Cold-Wall
GE and Hotpoint also did this, All the original two door top freezer GEs and HPs from about 1948-53 had a second freon filled cooling system powered off the freezer evaporator. This expensive design to build gave you a higher temperature evaporator which did not wring as much moisture out of the air, condensed water ran down the inside walls to a drain in the rear corner of the refrigerator liner.
Hi Laundreress , No it was not a disaster waiting to happen, the refrigerators evaporator tubing was behind a porcelain enameled steel wall, the only way to puncture or otherwise cause a freon leak would be with a 38 calibrator weapon, it was very built, LOL.
THE BIG PROBLEM with very high humidy in refrigerators is MOLD growing inside, Sub-Zero  had big problems with mold in the FF section of many of their refrigerators. My high humidity all ref in the pantry has to be taken all apart and the shelves etc bleached at least once a year and the defrost drain gets clogged at least as often and has to be flushed.
Hi John,
When you say Powered off the Freezer evaporator, you just mean via heat transference, or does the secondary coil actually have a refrigerant path back to the compressor?
Cheers
Nathan
When moving I bought a Samsung Combo cause it was on offer no more expensive than other even less reputable Brands.
It does have 2 moisture and temperature controlled drawers, one for produce one for meats and such.
Both are cooler than the rest of the fridge.
Never really belived in that but I do have to say that produce and such appear to last significantly longer.
Cold Wall
A high % of European fridges are cold wall designs or use cold wall and a recirculating fan.
The standard European fridge design has a cold rear wall with a channel at the back of the fridge that collects condensate that drains away into an evaporating tray sitting on top of the compressor.
Also the majority of them use a condenser that cools passively, not a fan driven one.
Even the most recent designs are partially cold wall. They’ve a very different evaporator design to your typical US fridge and the fridge and freezer cabinets are Nothomb to do with each other..
I remember we had a full height (2m tall) Bosch fridge freezer when I was growing go which had two compressors, one for each compartment.
cold wall design
Launderess its all about 2 things - efficiency and low cost.
My fridge is a Haier 220 litre 2 door. It was the cheapest 2 door on the Aussie market at the time (about 10 years ago) yet was super efficient by the standards of the time, though there are fully frost free models of larger size that use less power on the market now.
It has a manual defrost freezer of about 30 litres above a (cold rear wall) fridge of about 190 litres. It has been great for us.
the freezer is well insulated and has good hefty door seals. It only needs defrosting maybe once a year or 18 months.
The freezer evaporator is just a tube that circulates refrigerant around the freezer cavity - you only see the plastic walls of the freezer, the tubes are tucked behind. The refrigerant tube then passes to the back wall of the fridge compartment, again tucked behind the plastic rear wall of the fridge compartment. The tube zigzags down behind the plastic back wall, creating a cold surface area of the entire inner back wall of the fridge. The plastic is moulded to form a gutter at the bottom which drains to a catch pot on top of the fridge compressor and the condensed water evaporates away when the compressor is running.
When the compressor runs, the freezer chills first, then the refrigerant gas passes down behind the back wall of the fridge, creating a "passive evaporator" at the back of the fridge cavity before returning to the compressor. The back wall gets a light frost on it when the compressor is running but once the fridge is down to temperature and the compressor click off, the fridge temperature is still above freezing and the evaporator is only lightly frosted, the fine frost layer passively defrosts, needing no defrost elements or fans.
The simple way to think of it is that you are actively chilling the freezer compartment and getting almost "free" refrigeration of the fridge compartment simply by running the refrigerant gas down the back wall of the fridge compartment before it goes back to the compressor.
It is a very efficient system because you are getting your fridge cooled almost for free from the cold gases leaving the freezer evaporator, and because it is a very cheap to manufacture system with no fans, defrost elements, ducting, flaps, false walls and so on.
It needs to be precisely engineered to ensure that both compartments are kept within design temperature when there is only 1 thermostat, it only measures fridge temperature and it is assumed (designed in) that the freezer will be down to temp before the fridge thermostat is satisfied and shuts off. This in turn depends on the fridge being kept in a room that is warm enough to keep the thermostat cycling on often enough to keep the freezer down to temp. If the unit is installed in an unheated basement in a US Midwestern winter, the room is likely to be so cold that the fridge thermostat only rarely comes on, which would have the freezer warming up too much before the compressor came on again. That is my guess why these types of fridge aren't common in the USA.
I know that's a lotta words but that's the simplified version. Well, you asked...
Combo52 wrote:
"GE and Hotpoint also did this, All the original two door top freezer GEs and HPs from about 1948-53 had a second freon filled cooling system powered off the freezer evaporator. This expensive design to build gave you a higher temperature evaporator which did not wring as much moisture out of the air, condensed water ran down the inside walls to a drain in the rear corner of the refrigerator liner."
I have a 1951 GE combination as a second fridge in the basement, and it's totally amazing.  If I put a bunch of parsley in a glass with a little water in it, uncovered, the parsley lasts for weeks.  It it wasn't so ugly, having been painted with a brush in the past, it would be front and center in my kitchen.  As you say, it was an expensive design, and I'm sure that's why GE changed the design later in the decade.
I wonder if there's any significant difference between a "coldwall" design and a passive cooling design (i.e. think GE serpentine coils atop the refrigerator section or Kelvinator cold-plate along 3 sides of the top of the refrigerator section) with drippage into the drip pan.
Clearly the current "norm" in US/Canada is fan-forced refrigerator and freezer (was the first the Westinghouse Cold Injector?) with two controls (thermostat and airflow)
Cold Wall Refrigerators
Hi Chris, Reply #22, That is a great description of how a basic two door cycle defrost ref works Except cooling the lower ref compartment is not FREE by any stretch of the imagination.
When you put warm food in the fresh food section, fill it up after a grocery store run  open the door etc the compressor turns on a runs and runs even though the freezer was perfectly sitting near zero degrees it is using a lot of electricity to cool the ref section.
In the US we built millions and millions of these two door cycle defrost refrigerators and they are still built the world over. They are the ultimate in simplicity and reliability but fell out of favor for many reasons.
The down sides, uneven slow cooling and freezing of food items placed in the F or the FF sections, the freezer has to be defrosted manually and packages get frozen together hard to read etc. In the FF section anything that touches the back wall can freeze and be ruined, gets wet and things on the upper door shelves are not as cold, the user has to be careful where things are stored.
Reply #25 Magic Cycle Kelvinator
Hi Launderess, These used a hot gas defrost defrost system that quickly warm-up the freezer compartment shell and allowed ice to melt and then go back to freezing again all in about 10 minutes.
Other brands like Westinghouse did this with electric heaters which probably took a little longer.
The reason these systems quickly fell out of favor was they did not work well if the freezer was packed full packages would melt slightly and freeze together and defrosting was uneven and some frosty areas often either remained or grew over time, and customers did not like seeing frost.
The wisdom over here is a 7C fridge with produce drawers at 0-4C and meat storage at about 0-1C.
That is about 45/40/35F.
My Samsung is a bottom freezer self defrost system with inverter driven compressor, a heater for defrost and a single fan in the freezer section.
The drawers are fed by a baffle system with a slider that allows you to adjust cold air flow.
Dunno if you can acess this link but that is my setup:
https://download.aswo.com/service.p...t=0&checksum=2be015c975e8ae7f8ba0789821318a4d
One reason for the moist cool/cold wall design over here is also built in appliances.
About 75% of the kitchens I know have built in fridges and/or built in fridge-freezers.
They are only 55cm wide and have a limited depth and height.
While only minimal, a fan and compact condenser do take up some more space.
A cold wall design is pretty sandwiched on the back and the compressor is usually tucked in at the bottom so that the drawer is somewhat less deep.
On a built in fridge only that makes them self defrost aswell as discussed before here.
The evap temp is only sub freezing during compressor operation, thus any frost thaws once the compressor turns off, runs down the back wall through an opening into a pan ontop of the compressor to evaporate again into the room.
