What is your average drying time?
Our dryer vent goes straight up the house to the roof and vents there because our laundry area is in the middle of the house.
We have the Chimney Sweep clean it out when he cleans the chimney every other year. I think its a $20.00 add on fee. He uses those long flexible brushes and has another guy up on the roof to make sure everything comes out.
Now we have to take apart our Whirlpool dryer to clean it out, it's been several years.
Whirlcool
Exact same setup here. I have an electric leaf blower that I use to blow mine out. It seems to work well. I try not to wait too long between the cleanings because I don't want it to build up to the point that my method doesn't work, thus I do it about every four months. I got the idea from seeing a video of someone doing it on youtube. I would get on the roof I tried that once, never again. The pitch is way to steep.
take apart a dryer?
Whirlcool---sounds like a good idea. Do you take off the rear panel and then vacuum clean the lint that has accumulated under the drum? I remove the moisture sensor (just behind the lint filter in the inner rim of the 1442 dryer) quarterly and use a Miele crevice tool to suction out lint from below the drum, but I am sure I am removing only what's in the forward 1/3 or 1/4 of the machine.
Are there YouTube videos that show how to do this? I'd be game for it as long as it doesn't exceed my mechanical skills.
1.5 to 4 hours. Depending on the size of th eload and the thickness of the items in the load. You see my dryer (i.e. the heating element) has to work on 110v instead of the customary 220v. At half the voltage, the wattage is reduced to a quarter of the original. Threrfore 5,000 watts for the heater becomes 1,250 watts. So I basically have a dryer with the heat of a portable but a big blower and drum!
Moderate-size load of 10 shirts & 2 shorts, spun at 400 RPM (Delicate/Casuals cycle). Dried at medium heat (140°F, Perm Press cycle), auto-sense Normal dryness.
Approx 38 mins including cool down. May be slightly less, not sure if I noticed the initial end-of-cycle signal or if it was a bit into the wrinkle guard phase. Note that my dryer runs at reduced heat input (3,600 watts) on Perm Press (1,400 watts during reverse tumble).
1.5 to 4 hours.
Holy crap! They'd probably air dry that fast, especially outside, from spring 'till fall, lol.
Dryers, ugh, got too many of them!
The '81 gas Kenmore is the slowest out of the bunch and dries items well, but can by pretty uneven at times. Shirts seem to come out a little less wrinkled than the other machines. Probably due to the longer dry times. Dry times vary from 25 minutes for sheets to 2+ hours for bulky items like comforters. This dryer has been permanently banned for use with bulky items. Takes faaaarrrr to long, dries waaay too uneven, and requires repetitive flipping, turning, ect of bulky items to dry.
The DE808 drys items fairly quick and even. Almost dead nuts accurate in moisture sensing. Due to its large drum, bulky items, like comforters roll in a ball and take a little longer to dry, but not nearly as long as the Kenmore. Dry times vary, but with common loads, it beats the washer. Yes, impressive. Bulky items may need to be flipped once or twice, but is rather rare.
701/750/806's (all are Electronic Controlled): Dead nuts accurate moisture sensing. Dries items very even, quick and thoroughly. Factory 130F cool-down thermo is too hot, but a 110F replacement is perfect. All bulky items go in these machines since they get dried very even and quick.... no flipping is required. By far, my favorite designed dryer (except gas versions. Run away!!).
timed a load the other night
Eight shirts (all of them 100% cotton, about half with wrinkle-free finish which seems to reduce water absorbency to some extent) and two all-cotton trousers (also wrinkle resistant) washed on Perm Press cycle, Max spin speed; 2140's maximum is 950 rpm, I don't know how fast it spins on Perm Press.
Drying (Frig 1442 gas) took 38 minutes, including cool down. The "done" chime doesn't sound until cool down is complete, and I don't sit there watching the light to change from "Drying" to "Cool Down", but cool down appears to last at least ten minutes. Thus the load appeared to be dry, though not yet cool, in under 30 minutes. Sometimes when I'm in a rush (have to leave with the dryer going) I have removed clothes at the end of drying (but not cool) and it seems to be 25-28 minutes.
Before I got the matching full-size companion dryer
for my Speed Queen washer,I used a standarg 5Kg Australian made Hoover dryer that vented into the room via a louvred opening in its door. I never dried heavy denims or large bath towels in it and only used it for underwear, socks and shirts. A full load in that dryer would take at least 2 hours to dry on regular heat, sometimes even longer. I always made sure that the laundry window and door were open to allow the moisture and heat to vent. Bath towels and jeans would have taken even longer and I simply couldn't justify using the dryer for that length of time.
When people see my properly matched full-size dryer they always comment that it must use a lot of power and they are always suprised when I tell that this is not the case. It actually costs less to dry more. I now machine dry almost everything and drying times have been cut in half for almost twice the load capacity.
I don't do laundry every day and generally endeavour to do full loads most of the time. My average laundry day usually consists of between 5 and 6 full loads and, perhaps, three to four partial or small loads. With my matching dryer I can comfortably power through that quantity of laundry in a day. Partial and small loads consist of delicates and handwashables in the main, which get line dried.
It is a real shame that full-size dryers never became the norm over here and have remained a niche product that is mainly used in commercial settings like shops or apartment buildings.
Even in large homes architects will not lay out the laundry in a way that would easily facilitate the installation of a vented matching dryer to a large capacity top loading washer. When I look at new homes and home plans, the way in which laundry spaces are designed the placement of appliances appears to be almost incidental. There seems to be a greater focus on cupboards, countertops and storage spaces rather than an emphasis on placing properly matched laundry appliances in the best possible way and to do this with flexibility of choice for the consumer.
Olav...
....thats amazing...
I too had a Hoover 5kg dryer...a Supreme reverse tumble model from 1996...
I found that drying times were identical to the above when taken out of the same washing machine....and towels about the same but for a smaller load (4 + mats) out of the Hoover Electra 550 which spun at 800rpm as I wouldn't have gotten that much in the machine to start with...
sheets + 10min... and full load of mixed items about 70-80min out of the electra...
Quote: Holy crap! They'd probably air dry that fast, especially outside, from spring 'till fall, lol.
Can't line-dry in this apartment complex. Not even supposed to have a washer.
Olav: is your dryer gas or electric? Is there any such thing as a gas dryuer for home use there? For commeircial use? What is the wattage of your machine if indeed electric? Does it have a 5,000w heater, being 30a @ 240v (including the motor) or something less to make it plug-and play (13a to 15a)???
Toggs....
nearly all domestic dryers in Oz are electric. There is currently (to my knowledge) only one gas dryer on the domestic market here and that is a Euro sized but Oz made one...
A small correction and explanation
Hi rohnic,
Actually the drying times varied between 1.5 and two hours on average. Since the Hoover dryer didn't match my washer's capacity, I'd split washed loads in half. Thus, to dry one full wash load used to take between three and four hours.
At first, I machine dried towels and jeans also, always making sure that laundry had enough room to move around and it just took rediculously long. They'd also come out wrinkled.
Our home-grown dryers are not designed for constant, full-on use. They are really just good enough to help out on a rainy day or with light loads.
Comparing Euro and US style dryers, it is all about the size of the drum and how much hot air moves through the clothes; plus venting to the outside versus venting into the room.
My business partner purchased a Euro style F&P 7kg dryer last week. It is meant to be vented to the outside. It's vent comes out at the back and is identical in size and look to the one on my SQ dryer. Even though she has a massive laundry room, the laundry tub is right underneath the window. She has no choice, but to place the dryer against an inside wall. Her house is a rental and there is another floor above the laundry, limiting her options. Even if she owned the house, to place her laundry equipment in such a way that it would enable her to vent the dryer to the outside, would cost a lot of money, making it a very unattractive proposition still. She uses a LG top load washer with higher spin rpm than mine. Because of this set up it takes her longer to dry her clothes.
Toggles,
My dryer is electric. We considered gas, but the cost and inconvenience of having a gas line installed in the laundry room made us reconsider that option. My dryer stands underneath the laundry window and vents through there. A 20 Amp power point had to be installed at significant cost, but still cheaper than laying a gas line. Maytag (before its demise) and (the now defunct) Kleenmaid (Speed Queen) brand used to offer full size gas dryers to match their top loading washers. Currently Speed Queen is the only company that offers a full size electric companion dryer to match its US style top loaders. As I mentioned before, they are a niche product, very expensive, and considered to be industrial rather than domestic.
Unlike in the US, where residential developers include laundry appliance packages to purchasers as part of their deal, in Australia that doesn't happen.
On your side of the pond that has been the practice for suburban developments for many decades and set a different standard. Over here a Hill's hoyst in the back yard is still the standard inclusion with the off-the plan purchase of a new home instead. Laundry rooms were always small, came with the standard hot/cold water connections and a laundry tub. As a result dryers were designed to hang above the washer. They have to be compact, light and not require outside venting.
With the current trend to build bigger homes, laundry rooms have increased in size, but architects are filling in the extra space with cupboards, rather than allowing for the inclusion and optimal placement of what is considered to be an industrial sized appliance over here. It's a cultural and cost issue I guess.
More consumers are opting for front loader laundry stacks now anyway. The dryers match the washers, are cheaper and generally operate from a standard 10 Amp powerpoint.
Olav
Hi Steve,
The Big US style dryers here are 20amps 4800watts. Speed Queen is the only one left on the market. We never got the Whirlpool Dryers and the Maytags dissappeared when the Neptune/Atlantis did.
All standard size ones are mainly 10 amps 2400watts.
I really wanted the F&P TL dryer whilst it was still on the market here as a full load from the 5.5kg Miele washer overloads the 5.5kg Miele dryer. On a full mixed load I have to seperate it into Heavy (cargo shorts, heavy cotton polo shirts) and light items (Socks, Jocks and T shirts)
Michael however wanted a set that matched and when we got a flyer from Miele advertising that the Dryer that matched our washer was on run out and we could have it for 50% off, it was a done deal.
Both mothers have 5kg Hoovers, neither reverse tumble. I find that on Hot underpant elastic and stretch knit fabrics shrink, so I dry everything on Warm, which can take 90 - 120 minutes or more for a full load. Those hoover dryers dont have a true low temp. On Warm the heater element doesnt energise on every second timer increment. On the increments that it does, it heats to the standard Hot temp.
Well....
....my dryer gets fairly constant use these days....and by that I mean 6 loads of clothes and dog rugs a week ...
Which is hardly light duty.
I've never had a problem with times...and heat.
BUT
Both my dryers have been reverse tumbling....and when they do that, the heat cycles off and back on again making for a cooler cycle than the non-reverse tumbling Hoovers....
Well, reading this thread this week got me inspired to take apart my Kenmore HE3 Dryer and vaccum it out and clean it. So today I just now washed a load of whites, which consisted of the following:
8 white casual wear t-shirts (some with print on them)
8 pair of athletic/ankle high soxs
1 king size 250 thread count flat sheet
1 kitchen towel
1 dish cloth
Dryer was set on Auto dry Normal cycle (medium heat)
Total time was 38 Minutes and everything was bone dry.
Miele T9822 Gas dryer
Mixed loads spun at 1000rpms dry in 20 to 25 minutes using normal(medium) heat
Gym clothes washed using delicates cycle with < 1 min 300rpm spin, dried using delicates cycle, low heat, dry in 15 minutes.
Bath towels spun at 1000rpms dry in 30-35 minutes using normal(medium) heat.
The dryer also has a high heat(turbo) setting but I never use it.
With our old dryer
Our old Amana dryer.
Hmm....
I would say about 8 hours or so.
Thats when we realized that the heater was broke in it. XD
A few days ago I cleaned out my dryer vent, which goes vertically straight up, then a 45 degree turn out the roof. About 18 feet. I used this dryer cleaning thing I bought which works GREAT.....It's called the Gardus lint eater and it uses a cordless drill. I had always used a leaf blower but that wasn't working as well as I thought. I just did laundry today.....Three loads.......One was Jeans.....7 pair (dried in 40 min's).....A load of whites (with bath towels) dried in 30 min's and a mixed load dried in 35 min's......Cleaning those vents cut my drying time WAY down...Prior to this loads were taking about 50 to 55 mins and were not bone dry, these I just did were bone dry.
Room temperature?
Don't dryers pull air from the area they are in, heat it, and then blow it over the clothes? If so I guess drying time will increase when the surounding air temperatures are lower. My laundry is in an unheated area of the house so I guss my drying times might be longer in cold weather.
Very low (or high) ambient temperatures can throw thermostatic autodry off-kilter. Shouldn't have an effect on moisture-sensing autodry.
I dont know exactly how long ours takes, it is a 2009 Frigidaire gallery, and we put it on normal cycle, high heat, normal dryness, and I think it takes about an hour to dry a full load. the display shows 50 min when it is started, but at about 45, it goes to Ad,(auto dry) and will stay there until the clothes are dry and then it does a 10 min cool down.
Moisture sensor
I've never had any luck with the moisture sensor on my Duet dryer. There is a dryness level button for less/med/more dry. If I set it to medium dryness level and med heat, the clothes are bone dry by the time it cuts off. If I set it to low dryness level they aren't dry enough. So I just used timed dry since I have a pretty good idea how long it takes based on the load.
80minutes
I have an european whirlpool dryer..
A mixed load of 4-5kg spun @ 1200rpm takes 80 minutes.
A 6-7kg load around 100-110mins.
Full towel load take about 90-100mins.
As this is my first dryer I don"t know what to compare it to.. What do you think? is it too long, or just fine?
Thanks alot indeed ;)
