dustin92
I picked up a Kenmore HE4T free today, in non working condition (they weren't sure what was wrong with it, but with the info I was given, I suspected the bearings or spider had let go) Apparently it was making an awful noise and left plastic shavings on the clothes. I got it home and the drum was quite obviously loose, but I gave it a very short run on an extra low spin to see what it might do- clunk clunk clunk. Didn't even let it get to full speed. I started tearing into it, and it became very obvious the spider had broken. The front tub ring was eroded away, and there were some scratches on the glass door. Finally got everything disconnected, took the pump off, and the trap was packed full of plastic shavings and gray powdery metal chunks (I was told the pump had been replaced not long ago). I got the tub and motor assembly out, and the front off the outer tub, more shavings and metal chunks. The front of the tub had been worn through in several areas, and into the counterweight in at least one area. No pictures just yet, but I will try to take some tomorrow when I get the inner drum out. Then it's on to figuring out what all is needed to fix it. I'm going to contact Kenmore/Whirlpool because from all I can find browsing the web, the inner drum and spider are sold as a single part, but there is a lifetime warranty on the inner drum. In that case, the inner drum did fail, and damaged the outer tub when it failed. Hopefully I can talk them into sending out some parts, if not I may save up and just order them new, the washer itself is in pretty good condition, other than the broken spider (and a nasty smell of mildew, but I think that may have just happened recently since it broke, door was closed when I picked it up) Not really that much scum buildup thus far. The heater is clean (no hard water buildup) so I doubt the sanitary cycle was used much if at all. I really would like to get it working because it's top of the line with all the bells and whistles!
