hoovermatic
Damson Ketchup
8lbs Plums or Damsons
8oz currants
1lb onions (chopped small)
2 pints distilled white vinegar
2oz coarse salt
1lb demerara sugar
Tie the following in a piece of gauze:
6-8 dried chilli peppers
1 tbsp black peppercorns
1 tbsp mustard seeds
1/2 oz dried root ginger, crushed a bit first
1/s oz allspice berries
2 cloves garlic
First slit the plums with a sharp knife and remove the stones, then place the fruit into a preserving or large heavy-based pan and add the currants, onions and the bag of spices. Add half the vinegar, bring to the boil and simmer gently, uncovered, for about 30 minutes or until the mixture is soft.
Now remove the bag of spices, place the contents of the pan in a liquidiser and blend until perfectly smooth – if necessary sieve as well. Then rinse out the pan and return the purée and bag of spices to it, adding the salt, sugar and the remaining vinegar. Bring to simmering point and cook gently, uncovered, for 1½-2 hours or until the ketchup has reduced to approximately 3½ pints (2 litres). Stir now and then to prevent sticking.
In the meantime prepare the containers by boiling the bottles and their tops. When the ketchup is ready pour it into the bottles while they're still hot, filling them to within an inch (2.5 cm) of the top. Put on the tops immediately but screw them only half-way and if you're using the 'pop' type bottles push the top in but leave the lever up.
Next place the bottles in a larger deep pan (standing them on an upside down, heat-proof plate) and add warm water to within 1½ inches (4 cm) from the tops. Bring the water to the boil and after 10 minutes transfer the bottles to a wooden surface and complete the sealing.
8oz currants
2oz coarse salt
1lb demerara sugar
2 cloves garlic
