When you know the Human Race is doomed...
Light Years Away From the Louds
Like so many "reality" programs, there was likely a production meeting where this idea was floated because let's face it -- they'd be even more dull and boring without such contrived and exaggerated stunts.
At least I'd like to think that people their age couldn't possibly be that stupid.
@rp2813
You'd be surprised is all I want to say!
Some wouldn't even understand where the clothes go or even what button to push...
Foralysius: Link not working :-( Pretty black rectangle, though ;-)
Young, Dumb, Etc.: I worked three years (last 2 supervising) in a group home for teens, taught high school for 10+ years, and have interpreted in colleges for that long: IMO, 2/3 of the time the apple hasn't fallen far from the tree. I've heard the same over the years from countless teachers, psychiatrists, psychologists, social workers, etc. They all say the same thing: Half to 3/4 of dysfunctional kids come from dysfunctional parents/caretakers.
However, I think this was contrived because there's no way they'd think using the washer would be less work than Windex and paper towels, lol.
Sigh...
Is it my imagination that it seems the "Common Sense" gene or chromosome is disappearing rapidly amongst young people these days ?
Like in the Pressure Cooker Video... Why on Earth would you try to open that vessel with all that hissing and steam coming out of that pot ? Rex, you are absolutely correct that this NitWit didn't receive burns worse than he did.
Good Lord. This is really sad. Seems like Trial by Error is the Norm these days instead of asking for help or questions.
Actually, the guy in the pressure-cooker video probably was scalded on his legs and feet. Too bad there wasn't a follow-up video to show all the huge blisters.
The lid of a regular 3-qt. saucepan vacuum-sealed itself to the pan back when I was around 24 years old. I'd just purchased a new Whirlpool self-cleaning range to replace the 1966 36" coppertone double-oven range in our kitchen. Not realizing the pan had become a weak pressure cooker, I tugged the lid off. Water (I was boiling potatoes) flew out of the pan and hit my legs, feet and hands. Boy, did I have some nasty blisters just from that! Very painful, as well.
Lesson learned.
In these days-guess Moms&Dads are no longer teaching the kids the ways around a kitchen-not only learning to cook for survival-but to learn the hazards there as well.A kitchen can be just as DANGEROUS as Dads garage or basement workshop-learned the ways there,too!The kitchen can have things that can burn or cut you-the shop has things that can smash fingers cut you,and burn,too!
Link working. Thanks:-)
So, is it a trick of the light or does the moron actually pull the off the induction burner and put it onto a gas burner with a low flame on?
More to the point, what did he think was going to happen when he opened the lid?
Normally I'd assume he left to hop into the shower to douse himself with cold water, but I'm probably overestimatiing his brains.....
My Grandmother, Mother and Mothers Sister
All used Pressure Cookers, and none EVER blew one up, I grew up using one and I never blew one up, Now Daddys sisters, that was a different story..LOL, Aunt Mable, who had the cleanest house on earth, cooked turnip greens in hers...you guessed it, the whole kitchen got a GREEN paintjob in about 5 seconds!!LOL...I use a pressure cooker all the time, but there are things you DO NOT DO!!
Washer dopes-hand dishwashing detergent in the detergent drawer of the washer!Then the foaming!!!!!Why didn't the moroons just turn it off?Yes,they did end up with clean placemats-and a clean kitchen floor,but no scalding as what would happen in the pressure cooker incident.The cooker that exploded-Mom has used hers as long as I remember-no explosions.Follow directions-make sure the pressure regulator is working and not clogged with food.It looked like no one was in that kitchen when the pressure cooker blew in the other pressure cooker video.Glad for that.
"Gramma"...
Always showed me when washing the lid was to invert the cover and fill it with hot water and let it run though the Pressure Stem where the regulator sits. She said "That way you know it's clear and nothing is stuck in the pipe."
She also would once a month remove the sealing rings and wash them to remove what she called "germs". Then replace them with the slightest film of Vegetable Oil to keep them soft.
I still have that Pressure Cooker and use it often.  She always told me to NEVER leave the kitchen when it was on the stove.
Idiots
If you need to quickly reduce the pressure in a PC you just sit it in the sink and run cold water over it till the pressure is gone, even with cold water if the PC is fairly full it might take a few minutes to reduce the pressure.
Just don't try this when you have canning jars in the PC as reducing the pressure quickly will cause the jars to explode or break.
If he really wanted to open the cooker quicker, he should have just placed it in the sink and let the water run over it for a minute or two until the pressure went down.
The pouring of water on a hot PC was something you would do in an emergency.Not routine use.And the hot water poured into the lid to see if vents were clear-now it comes back.Haven't seen or used a PC in years.Yes,also the seal ring in cookers where it was easily removed-soaked in vergetable oil to keep it soft and so it could seal properly.A hard seal won't "seal" same with the vapor steam cooling of the tubes in some of our transmitters-the tube seal rings have to be moistened with silicone grease and same with the seal rings in the tube steampipes.These won't explode-just leak steam-and when they do into components with 15Kv on them-you get some good arcs and burning!Sometimes the steam cloud will ionize and glow a weird etherial blue purple color before arcs begin.
Pouring Cold Water On A Hot Pressure Cooker
Hi Rex It Is recommend in the instruction manual of all the PCs I have and I do it all the time.
Usually if it is cold in the house [ heating season ] I just cock the regulator and let the heat and steam escape into the house, in the warmer months I almost always just set the PC in the sink and turn on the cold water and let a lot of the excess heat go down the drain.
I have been doing this for years, I often use a PC up 5 times a week, check your instruction book.
Reply #1. That dude had to be strong. The PC looked similar to our Fagor. I honestly don't think I have the strength to pry the top off our cooker. The safety interlocks are very sturdy. Not that I would try it.
I was concerned the very sudden cooling of the cold water could warp the pot.I haven't used a PC in many years so I may have forgotten some things.What I did learn was from Mom,Stepmom,or grandmother-one of them cautioned about pouring cold water on a really hot PC.If its Ok in the manual-guess it can be done then.
both
of my stainless Prestos and my one aluminum Mirromatic all say, depending on the recipe, "reduce pressure immediately by placing under cold running water" or "let pressure drop of its own accord".  Depends on what is cooking inside.  I've tried to open my old Mirro with just hot water in it barely beginning to steam and can't.  My two Prestos have interlocks on them...if there's pressure inside they CAN'T be opened.  I was at a neighbor's house when I was a kid and their PC blew the safety...the range hood caught the steam and rained down hot water onto the electric cooktop.  That was exciting but I'm glad I didn't have to clean it up!
Never had a pressure cooker explosion
I just used mine yesterday as a matter of fact. I was taught that once it reached pressure, to turn the burner down to low to medium heat and start timing whatever you're cooking, then when it's done, gently take it to the sink and run cold water on it to release pressure -
I wonder what this person did to cause the explosion? Left the burner cook top on high after it had reached pressure? God, what a mess!
