where could I get hold of...
aquarius8000
Mar 21, 2011
1,537
Hi all. My aquamatic is making a rattle noise and to my conviction I am presuming it is the bearings. Sofar I have tried Espares and Ebay. I cannot think of anywhere else to go. If it is not what I am presuming please could one of you load some more suggestions
Thanks, Chris
well,
The washer is still my friend but my dream machine is on Ebay. If I did buy it then i may see abuot making a bearings my self as it is a family airlune. I would be sad to see it be taken to the tip.
Chris
What model was it? Was it the aqua10? If it is I have a scrap one that has just come in with bearings that are fine. If that any help, gimme a holler. I am also not far away from you, about 15 miles!
There should be a second bearing but I can't tell which one it is, although if you got the old one out you should be able to buy a generic one to match.
Tom
a google search shows this as a common 6203 bearing; sounds small. ie a 17mm bore 40mm od and 12mm width. This bearing is very common.It was used on the Generator of Fords 1930's model A car; it is used on a 2011 car too. Here in the USA they are so common that that cost about 2 dollars as singles at a auto parts parts house.
Yeah like I say, there are two bearings, I'm just not sure which is the second because there are multiple parts listed for the same model.
It's important you replace the bearing seal because the reason the bearings fail in the first place is because the seal has gone. The seal is the only part which is a potential problem, luckily it is still available in this case.
Tom.
