"I do have some more experince in that matter"
Well, older does neither mean better or smarter.
I actually hate it with passion if somebody states that argument. "But I am xx years older then you, so I have to know better!"
You don't. Simply, you don't. You can, but not because you are older. I probably know more about physics then you do. And I am younger then you. Why? Because my main occupation is study. School, Internet, etc. Age is by no means directly relatable to knowledge.
Oh, and, does a G5100SCU count?
Made these picks few months back while staying at a friend for 4 days.
I have to admitt, the loading needed some adaption, but once you knew that if something stood in there while loading, it won't move while washing, you got the turn.
Pic 1: Build-under, perfect stainless steal.
Pic 2: "Old" UI. Cycle layout is different by now. The display for some reason only displays the delay start. It is supposed to work while programming (water hardness, for example), but dosen't. It is not brroken, just not used for anything but delay timing. That load wasn't documented, but was even more packed, though, less soiled. Only 1 item did not come clean in this load, which was a Crepes-pan.
Pic 3-5: The lower basket of our party evening load. That grill plate should not have come clean. (Spoiler: It did.)
Pic 6: The stuff crammed under the grill plate.
Pic 7: Upper basket. Yes, these pans were just as heavly soiled as the plate. ("Spooiler, they did come clean.)
Pic 8. That's why I love the tray. Capacity. Not the fastest to use, but just gives so much more space for cuttlery and other stuff in the lower basket.
Pic 9: Big amount of Somat powder. Needed with all the burned on stuff like potatos.
Pic 10: Serial plate.
Pic 11: Running the Intensive cycle.
(Sorry for the bad quality. I shot them at 3am in a rush with my phone.)
