Under Filling WP PC DW
Or just about any other DW
Unless the inlet valve screen is packed with stuff to the point you can not see the screen and the stuff is more than 1/4" thick, don't waste you time cleaning and old valve, Replace it with a new valve, the problem is the rubber valve diaphragm is failing [ unless the valve is old enough to be screwed together and you can find a valve rebuild kit ]
By the time a DW valve is that clogged every faucet, shower head and inlet valve for the washer has already clogged several times over, you would have some seriously contaminated water, normally with a tank type water heater most foreign particles fall to the bottom of the tank and stay there.
John
