Hi Guys
I've attached a pic from the old Whirlpool Products to show what it looks like. I'll take better pics later.
It was give away as it wasnt working at all when I got it. With the help of the technical manual, its little computer told me the Anti Flood float switch was showing a flooded situation. I took the drip pan off and had a look and all it was, was the connector was off the float switch.
It fired up no worries after that, but the plastic wash pump is leaking. I'ved orded a new Motor/pump unit and it should be here this week.
This model is about 8 years old, and is back from when Whirlpool DW were very uncommon in Australia. Its German made and from all accounts its a highly acclaimed machine in Europe.
I'm pleased with myself as for $200 i've got a $1200 AUD dishwasher.
Do any of the American Dishwashers have anti flood devices? The Whirlpool has the inlet solenoid where the hose connects to the tap. So unless the valve is opened electronically, there is nothing to burst. Whirlpool call it their 'Aquasure' System.
Under the dishwasher there is a big metal tray, (Like a baking tray) that has a float in it. If the float is raised by water, thus alerting the computer to the fact that there could be a leak (Or a wire off) the wash pump stops and the machine drains for a 5 min interval.
The other thing I learnt from the technical manual, is that pressure switches have been done away with. It electrically measures the water inflow and counts the number of litre's until it is full. In case of a pot turning over and catching the 4.5L it takes to fill the machine, it has another sensor which measures the rate of flow of water comming out of the pump, and the number of revolutions that the spray arm is doing. It'll add more water and if that doesnt increase the flow rate, the machine again stops.
The computer can display about 15 error situations to test the sensors in the machine. This makes it very easy to work on.
I've waffled enough now
Nathan
Nathan
