Whirlpool Direct Drive compatible alternate agitators
shanenc14
Aug 10, 2018
70
Tennessee, USA
I have a Whirlpool Direct Drive (GSW9800PW2) with the dual action agitator. I'm thinking of trying an agitator with vanes, if I can find one that will fit, instead of the dual action.
Can someone give me some part #'s or point me in the right direction on what options are available other than the OEM dual action corkscrew?
Wow! That 3rd agitator looks like it would demolish some stuff on High agitation speed! I do remember the 2nd one on a machine I had in the 90s.
Duel Action Agitators
Yes Agreed Martin and Eugene, The DAA was the best thing that ever happened to traditional TL washers [ If Wringer Washers Were Built Today They Would Even Have DAAs ]
While the older one piece agitators were often neat to look at and fun to watch work with light loads the DAAs were just much better performing and easier on the clothing [ Even on the MTDC washers the best thing that ever happened to them was the Load-Sensor Agitator with the shorter stroke orbital transmission that didn't DRAG your clothing from hell and back while trying to turn it over ]
In any event Shane have fun trying different agitators in your washer, there are at least 15 different agitators that will fit your machine.
Yes, that one will fit any direct drive machine except the 24" cabinet version...
better if your machine has a speed selector switch, as some feel a slower speed agitation is preferred.....
note: I have used mine at both speeds with no issues.....your mileage may vary
Also, would my existing agitator bolt work to attach any of these agitators, or would I need to order a different one? i.e. different length or something?
Yes it will fit and work. It was made for the smaller capacity direct drive machines. The action on small loads and possibly medium will be good, but on a full load it won’t be very effective at all. Same bolt will work. This looks like one of the agitators that the top half pops off and there is a manual lint filter to clean inside.
My grandparents had an agitator just like the one pictured in an early 1990’s Roper extra large capacity (standard not super capacity). You could pull the whole top part of the agitator out to clean the lint filter that was made on to the bottom of the top part while the base stayed bolted in the machine. The holes in the side were what ran the water through the filter due to agitation. I think I only saw one other one than theirs that was built this way. There was also a two piece like this one but did not have a filter and the bolt went through the top part not allowing it to be removed. Their machine looked almost exactly like this Estate model.
of all the straight vanes versions they offered......this was the best at cleaning and turnover for some odd reason....
could be in part to the wavy Surgilator vanes.....plus the five blades...
I remember these in the first direct drive 24" Design2000 machines......with the barrel lint filter
