Whirlpool Dryer Rescued from the Scrap Metal Yard.
Conpact WP Dryers
Yay another one saved Louie,
The chain that is mentioned on the racks sticker was to be attached to the wall behind the rack and to the rack to keep the whole thing from tipping over if you decide to try hanging from the open dryer door.
The newer style heater, which is much smaller in length gets much hotter than the older dryers heater where they actually used a 5600 watt 240 volt element and ran it on 120 volts, even though both types put out the exactly same 1400 watts when run on 120 volts.
John L.
Thanks Gan!
John, any reason why the element doesn't get so hot, so quickly now that I reinstalled the drum? Check out the videos and you'll see what I mean. Without the drum, red hot super fast, with the drum, slow and dim. Did I reinstall something wrong?
And thanks! Looking forward to seeing you and Jeff this Saturday!
you did an amazing job!!!
there louie!!!
WOW!!!!
and i KNEW it was just a matter of time before we see the pictures of the washer, dryer & rack all set up!!! i was actually hoping to see it soon!!! LOL.....
that little set up looks really snazzy!!!
you know, you really do an "OUTTA SIGHT" job with getting the portable dryers all spiffied up!!! i can't even imagine the great sense of accomplishment you must feel when you get done with each dryer. they look brand new!!!
thanks for sharing your progress louie.
:o)
and that is strange....
why did the heating elements get so hot & bright without the drum on??? but when you had everything assembled, the heating element didn't look as bright & hot as it did.
element
With the dis-assembled dryer for test purposes, you arent getting much, if any, airflow over the element, so it can get real hot real quick. When fully assembled with the drum installed, even if you have the door open for pictures while it's running, the blower will pull a decent amount of air over the coils, properly pulling the heat into the drum instead of letting it build up and get cherry red glowing. Then, with the door closed, you've got approx 100% of the airflow pulling air over the element. That way it may glow a bit, but not much, and the correct overall airflow from intake over the element, into the drum, thru the clothes, out the back right perf area, down to the blower and out of the cabinet will all work as designed.
It's wise to test elements and such while re-assembling, but not for long. The airflow and safety issues are wrong for more than a quick test.
that makes sense....
thank you for the detailed explanation akronman. i can actually see it happening, the way you explained & described it. and it totally makes sense to me. thank you for making it very easy to understand. cuz i was like, "huh, how come???".
thanks again akronman.
;o)
Hey thanks Christina. I just love that rack. Going to make a big difference when I finally build my laundry closet.
You're right Mark. Makes total sense why the heating element was heating up so quickly. Thanks!
Well, the mid-80's Whirlpool dryer has died. According to it current owner it does nothing when switched on. It's seen heavy use without fail since it left my hands some years ago. Could it be the power switch went bad?
Update. It was a broken element wire. It snapped right where it gets crimped for the exterior spade plugs. I can easily slip the wire at the other end of the crimp tab. My question is, will crimping be enough, or should I solder just as an extra precaution?
Fixing A Heating Element Terminal
Hi Louie, so the dryer was running and not heating I gather from what you found wrong.
You can fix the element if it has the old flat steel terminals by drilling a hole through the terminal and using a small steel nut and bolt and a few steel washers, crimping probably will not work for long.
A picture would be really helpful as WP has used three different style terminals systems on these dryers over the years and there are different ways to fix them.
John L.
Hey John, thanks for the advice. The element snapped right at the terminal that is buried inside the ceramic insulator. There is not enough material protruding from the insulator to drill. Just enough to crimp. I'm keeping my fingers crossed.
John, can you mail the knobs for the other dryer that I need? I can't drive down for now. Be happy to pay for the mailing. Thanks!
