Fixing A Heating Element Terminal
Hi Louie, so the dryer was running and not heating I gather from what you found wrong.
You can fix the element if it has the old flat steel terminals by drilling a hole through the terminal and using a small steel nut and bolt and a few steel washers, crimping probably will not work for long.
A picture would be really helpful as WP has used three different style terminals systems on these dryers over the years and there are different ways to fix them.
