Hi all,
I purchased a used Whirlpool dryer (model # LET7848DQ1) a couple of weeks ago that I finally had time to fool with. I cleaned everything up on it, etc. and dried a load of towels in it. The issue I am having is with using the "Auto-Dry"--the timer never advanced, it stayed on the "Max" setting. Now, using the "Timed" dry setting---the timer worked just dandy.
Any ideas why the auto-dry is not working correctly? I suspect it may be the electronic control board, but thought it prudent to check with folks more knowledgeable than myself
As always--Thank you!!
Mitch
Mitch
