Recently purchased a Whirlpool Duet Washer model GHW9250ML. After hooking it up I ran it through it's first cycle without any clothing. The spinning noise created by the drum was surprisingly quite, however, at several points in the wash cycle (one towards the very beginging) the machine emmited a relatively loud noise which appeared to be coming from the base of the machine.
The sound does not appear to be a rubbing or gurgling noise, but rather a mechanical pumping noise (grrrrum grrrrum grrrrum). Compared with the rest of the cycle this sound is *significantly* louder. Does anyone know if this is a problem or the normal operation of this washer.
Also, I have come across some discussions regarding older Duet models where owners purchased a "pad kit" from Whirlpool. Any information on what is is about?
Thank you.
-David
Thank you.
-David
