Whirlpool Frontload Washer with Timed Dry Button
DADoES
Moderator
Staff member
May 21, 2001
16,424
TX, U.S. of A.
Visiting a Lowe's today, there is a Whirlpool frontload washer with a TIMED DRY button.  I don't know the model number.  I didn't take a photo.  I asked the sales girlie, she said it's a dryer.  Nope, it's a washer, see here, the detergent and softener dispenser drawer and the Drain & Spin button, a dryer would not have a Drain & Spin function.  She, confused, went to check documentation somewhere, probably at Lowe's website, came back and said there's nothing about a Timed Dry button.
The matching dryer was sitting atop it, also with a Timed Dry button in the same position on the button array.
Did I find a factory production line foul-up, the wrong button overlay on it?
Only a guess but aren't there now washer/dryers that connect to each other so after a wash cycle and depending on what cycle you used, it would automatically set up the dryer cycle. Maybe the "timed dry" button is to negate that so you can set the dry cycle yourself?
Dual options on the TOL front loader
12-Hour FanFresh® Option
Keep clothes fresh for up to 12 hours after the wash cycle has ended. A built-in fan activates after the wash cycle is over, tumbling clothes for up to 12 hours so you can finish laundry when you're ready.
Wash and Dry Option
Let the washer keep laundry moving for you by adding this option to select wash cycles. After washing ends, it uses hot air to tumble dry clothes right in the washer.<sup>4</sup>
Whirlpool is using the exhaust of the dryer to heat the washer by a deflector valve or something.
<span style="font-size: 14pt;"><sup>Anyway, t</sup><sup>he online reviews on the Whirlpools website are a no go for me.</sup></span>
<span style="font-size: 14pt;"><sup>One of my YouTube influencers had a Whirlpool appliance nightmare. All of his brand-new appliances broke down.       </sup></span>
<span style="font-size: 14pt;"><sup></sup></span>
https://www.whirlpool.com/laundry/w...oad-and-go-xl-plus-dispenser.wfw9620hbk.html?
Bob, I don't think it's a combo, the price didn't register to my attention as high enough unless it's mis-labeled.  The Timed Dry selection is on the bottom of the array of center black buttons, I believe in the same position as on the dryer stacked atop of it.  There may be an opportunity to get photos in about 3 weeks.
4.5 Cu. Ft. Ventless All In One Washer Dryer
It appears to be a combo with condensing dryer. For the price ($1394.10), it sounds like a bargain! The owner’s manual (found on the page linked below) seems incomplete and has hardly any info in it.
Description
Do laundry the way you want in a large capacity all in one washer dryer that installs virtually anywhere. Whether your laundry area is a closet or mud room, fit this space saving washer dryer combo and wash, dry or wash and dry all in one appliance. Plus, skip adding detergent to every load with the Load & Go™ XL Dispenser.
Wash & Dry Option
Wash and dry an average sized load in 3.5 hours, all in one appliance.
All-In-One Washer & Dryer
Whether you need to only run a wash cycle, just dry a few items or wash and dry a whole load, the All-In-One Washer & Dryer gives you the flexibility to do your laundry the way you want.
Space-Saving Design
Closet, mud room or full-size laundry area—no matter what your space, take up less room and do laundry in one appliance instead of two. With a ventless Space-Saving Design and 33" installation depth, the All-In-One Washer & Dryer can be installed virtually anywhere with a water hookup.
Largest Available Capacity in Its Class at 4.5 Cu. Ft. (Among full size All-In-One Washer & Dryer brands.)
With the Largest Available Capacity in Its Class at 4.5 Cu. Ft., this All-In-One Washer & Dryer provides enough room for day-to-day loads, while still fitting in the space that’s convenient for your family.
Intuitive Controls
Let the All-In-One Washer & Dryer guide you to the right cycle combinations or customize up to 41 of your own wash and dry cycles to get the right type of fabric care for whatever you wash and dry.
https://www.whirlpool.com/laundry/l...ntless-all-in-one-washer-dryer.wfc682clw.html
Joe thank you. Link to that product was included in my reply #3. I've know about that product since almost the beginning of this current generation release 2-3 years ago.
I had intended to get photos today of the mysterious washer with Timed Dry but we went to a different Lowe's ... that didn't have any Whirlpool frontloaders on display.  :-(
