whirlcool
Our Whirlpool Electronic control washer from 1993 has started to act up on us. When we were washing clothes this morning we noticed that when it reached the end of the wash cycle, it just stopped. It did not go into the neutural drain and spin. It just sat there. The machine did not power down. It just sat there.
I pressed the "spin" button on the control panel and it started pumping out the water and went into a neuteral drain and then started to spin normally.
I ran it again, and I noticed right after the wash cycle ended the lid switch made a few clicking noises. It didn't do this when I selected the spin option. It only does it at the end of the wash cycle.
Could this be a control board problem? I think it could be because all the mechanicals in the machine are working, but the error occurs only at the end of the wash cycle. When you press the "rinse and spin" option, it works fine. It rinses and then goes into the drain and spin mode. There are no error codes on the control panel.
Am I on the right track?
