Whirlpool LHA 6 800
I wasn’t quite sure when I called Whirlpool they told me either 1980 or Fri. May 7, 2010 lol I told her it had to be 1980 because I know they are older than I am.
Model# LHA6800W1
Serial# CO1908386
Oh ok thank you so much🙏🏾she did say something about the 19th week as welll. I’m not sure how to take care of it lol I’m learning because I want it to last but I noticed it makes a squeaking noise when in the spin cycle. Any tips lol? Do you have any pics of the matching dryer so I can keep an eye out for one.
At this washer’s age it is likely that it needs a mechanical rebuild that repair people these days are not interested in doing due to the time involved and lack of knowledge of the machine. It is older than most of the repair people. Lol Parts are still fairly available which is hard to believe because this design was discontinued in 1986. My advice would be to make sure the belt is tight and use it as is if everything works and it doesn’t leak. As to the matching dryer it would probably be easier to find than the washer. I would recommend the larger capacity model as this is the 18 pound washer which can handle a pretty large load. Mine is a LHA6900 built early in 1980 as well. First picture is the washer I have. The second is a 1980-1981 LHE5800 model dryer from the archives that was built in late 1979. Are you mechanically inclined?
Early 80s belt Drive whirlpool washer
Hi Andrela and congratulations on your cool washer. Depending on how much use this machine had you may get a lot of use out of it or it may be near the end of its run. Do you have any idea how much use it had in its prior life.
The machine should be serviced. If you’re concerned about it the belt should be checked. It should be checked for leakage. The clutch pulley bearing should be oiled in just a little bit of tuneup may keep it running for a long time without having to do much to it if you’re lucky.
The standard capacity LH 5800 series dryers are plenty big enough for this machine that was considered a matched pair when it was made some people who consistently did huge loads, like to have the super capacity dryer as well but it’s only one cubic foot difference you’re going from 6 to 7 ft.³
Are you able to work on the machine or do you have somebody that can where you live?
John
Thank you all so much you have been a great help🙏🏾I’m a little mechanically inclined lol but not much. I finally figured out how to open and clean on top of the drum lol. I couldn’t even tell you where the belt is or anything else🤦🏾‍♀️I don’t know anyone near me to fix it. Yes, thank you again for the dryer pic’s I think I might have found some on Facebook marketplace
Oh ok 👍🏾 yeah they seem like very dependable/durable washers. I was going to buy a newer one but my grandmother’s friend had one for sale and I’m glad I purchased it🙏🏾They are way better than the newer ones.
Oh ok thank you 🙏🏾 I was wondering what that little door was for but I wasn’t going to take something apart and mess it up my luck lol I opened it and dusted a little but I don’t know that much about them🥲I’m currently looking for someone near me to help lol
No I’m not sure I would assume moderate use. It wasn’t super dirty inside and a fairly newer belt still had grooves🤷🏽‍♀️I’m still looking for some one nearby to do maintenance🥲Does anyone happen to know the part numbers for the softener reservoir and lint filter? Thank you 🙏🏾
The lint filter on this washer is self cleaning. While the machine agitates the filter captures lint and when the machine drains it flushes the lint out of the filter and sends it down the drain. Here’s the fabric softener dispenser:
