ovrphil
Hi friends,
Two years ago 2015 I bought a Whirlpool W & D set. There wasn't a way to plug in the dryer, but I did check out the washer. I carefully brought it back to the apartment and it sat in the garage for about 10 months, til we moved to another apartment. A two man crew brought the set into the laundry room..and I was ready for its maiden wash. The washer has worked fine. Once outfitted with right three-prong plug, the dryer panel lit up and seemed to be ready for any choice. I chose a Normal setting and pressed start...and then a pretty obvious clunk click - something really bad. It didn't take long to notice why...see photos.
Knowing it would be less costly to replace it with another dryer, I got lucky to find another identical unit about an hour or so away, and I've been using it since. I realise that having a second machine for the control panel is always a plus...but recently, I looked at what it might cost to replace the drum(see $99 for a drum)just to have a backup. Often, yes, a CL find might turn up something as much or less than replacing a drum-possibly the least painful path, but these aren't always easy to find nearby at $100 or less.
Has anyone replaced a drum or disassembled one of these dryers to share, what is involved? Also, has anyone ever seen such a cracked drum before? Any ideas about how this could happen? I don't think the drum can be fixed, but maybe some of you experienced people have repaired a cracked drum - seems like a bad idea, though. Also, I have no idea what lies beneath, but the drum rotates on something that could also be demaged.
So, at this point, I haven't downloaded a service manual or studied what's involved, but I have been thinking of saving this dryer versus removing the board and letting the rest go. Maybe.
Thanks for any ideas, shared experiences or opinions...
I
Phil
I
Phil
