murando531
I was in Lowe's today, and for whatever reason a new Whirlpool dishwasher was upside down on a dolly. Not sure if it was a display or what, but the door was bent. I took the opportunity to scope out the underside since I've never seen the motor assembly in person, but I didn't get to sneak pictures.
I have to say, I knew that WP was putting much, much less powerful motors in their line along with their KitchenAid and Kenmore models, but I was shocked to realize that the main wash pump is literally a slightly larger induction motor, identical to the motors being used as the independent drain pumps in washers and dishwashers.
It makes sense now why they can't use all arms at once, or have a chopper blade equipped; they simply don't have the power. This is also the same motor type that is used in fountain pumps, and the one that sometimes makes sort of a chatter when kicking on in your washer/dw during drains because the magnetic pulses kick the rotor back and forth rapidly until it has enough momentum to spin in one direction or the other. On one hand it's to be expected with the energy "issues" these days, but I would never think that a glorified drain pump would have the power needed to put out good volume and pressure from the spray arms in a dishwasher.
This also makes me wonder that if you put your ear down next to the machine when it starts up, will you hear that telltale chatter that induction motors sometimes make? I'd also like to hear anyone's experience with these models, as this type of motor typically isn't supposed to run more than a little while at a time.
