Whoa! TOL living
Wow, I missed that!
I just got a few more 1-18s! Not all working but I should have a few interesting projects! But still no Elites!
Among them, the rare CSA-approved DECI-CAN dryer!
combo
I have not had quite the same experience with the 1-18 washers as you have had I guess. I did use them at the commercial laundry I ran for about 20 years and they worked quite well. I also had them at home off and on for many years. On a reliability level, I don't think they could come close in comparison to an old Maytag of the same vintage. They were also a lot of trouble to work on. I personally found the roller matic machines that Frigidiare made just previous to the 1-18 machines to be far more reliable and easier to maintain than the 1-18 machines. Frigidiare machines in general had more parts that would wear out with excessive use than most other machines. For instance, if the tub seal on a 1-18 model failed, it usually mean you had to completely tear down the entire machine and replace the bearings. With the previous solid tub models, that was seldom an issue. The 1-18 dryers constantly had air flow and drum roller problems and the lint trap baffle warped on many of them. I just think that Frigidiare really could have done a better job designing these machines. When they worked, they worked quite well and the trouble seemed to vary from machine to machine. They just had many weak points that caused problems. That is probably one of the reasons Frigidiare sold the appliance line. I will have to say that I enjoyed my Frigidiare set while I had them running and miss them. Perhaps I can rebuild yet another set at some point to use again.[this post was last edited: 12/4/2016-06:49]
John,
I've known a few MS from my upbringing, but I may have missed anyone here being called one. Can you give me a clue?
In high school, my buddy's dad called his mom one as well. If he disagreed with her, it was an occasional war.
In the period where it was trendy to write Heavy Duty on laundry machines, Frigidaire also had to write it on it's 1-18 washers but for some reason, they skipped doing that on their dryers!
Frigidaire closed it's Canadian factory in 1970 and they didn't sell that many washers and dryers here compared to their other product lines like built-ins, ranges and refrigerators.
Then, they went away from the Canadian market for a few years (I think GM wanted their appliances , which were built along with auto parts at the Canadian factory to be exempt from import taxes from the Auto pact but that didn't work).
In the mid-seventies (around 1977) a company named Elitech started to distribute a partial line of Frigidaire appliances. Dryers and ranges were made by Frigidaire in Ohio to meet the CSA requirements (most of the other appliances already sold in the States were also CSA approved at about the same time so they didn't need modifications)
But their distribution was marginal in the Canadian market and the prices were not very competitive. That is until WCI took over from GM...
So unfair
Not only do you folks have washers in cool colours but they knock spots off the machines we had at that time.
Love the red and in particular love those machines that bob up and down I only ever remember seeing one in a laundrette which sadly has long since gone.
I did something similar with my white 1973 WCD3T washer, no rapid advance but I replaced the console by the one from a 1976 WIC and I replaced the motor and wiring so it now has 3 speeds. 1976 was the last year for 3 speed motors in Frigidaire washers.
I also finally got a drying rack for the 1-18 dryer!
Here's a small video showing the 3 speeds!
