Whoa!
Yes....logic..if you keep it on the bottom it will bubble inside for liquid over it so hence splash due to the fact in needs to take air and will be an intermittent flowing.
It helps making an hole on the back side, though it will not be tight when you have to plac back in the refrigerator, it works with milk cartons though where both side can be opened and re-closed....
Same reason why also some liquid detergents like Persil do have a small hole which oppose the spout, Tide instead has a carving that goes till the bottle ring for the same reason.
And blah blah blah...
