Why I dislike detergent pods - stuck in Miele door seal!
iej
May 2, 2014
1,929
This photo explains all. Detergent pod was placed way back in the drum and bounced onto the door seal area during the first few tumbles.
My favourite part actually comes after this - it's when the pod starts to break up, and one observes it slip right inside the door seal in a sticky mess. To add insult to injury it will normally sit right there for the remainder of the wash only to be dispersed on a high level rinse.
What a wonderful advancement in technology they are ;-)
That's assuming you have a high rinse level. It could just as easily stay there until the end of the cycle.
Luckily that W1 is set to do deep rinses so it should have gone somewhere.
You'd wonder though, how many are actually getting dispersed in the rinse cycles where people just don't notice. Most people don't pay much attention to their washing machine once it's started.
This happened one time with me in an older Miele 1986 which was using the water plus option in the wash.  I had to open the door and manually flick the pod back into the tub.
Because of this and the fact that one pod is too much for a smaller load, and for me the Tide pods smell awful, I am finished with trying a pod in my washer.
Done with it.
No problems here
Pods are supposed to be placed into the machine before laundry. Thus as the tub fills contact with water should cause the film to begin dissolving. The rest if needed would come with the first few tumbles of the drum.
In either my high water use Miele or rather stingy Oko-Lavamat have not had a problem with pods not dissolving and or becoming lodged in the boot/door. Gel detergents placed in cap dispensing devices OTOH are another story.
not a big fan of them, but they do work......noted, that one pod is for a medium size load...same goes for noted loads per bottle with liquids, again, not everyone reads the instructions....
noticed they break open quicker under HOT water.....cooler to cold temps take a little longer...for those times, its best to dissolve in a glass of hot water, then add to the machine...
sometimes you have to adapt to what your working with....
I've been using pods (various brands) for months, and this happened only twice. The tumbling clothes bumped it back into the tub after a minute or two on both occasions. It seems to happen more frequently on machines with a wider space at the boot; maybe I'm just lucky. I always put the pod at the back of the tub, then add clothes. This "stuck in the boot" scenario is a common complaint about the format in user reviews.
At any rate, the longer I use pods, the more I like them...which is a good thing, as I have about 300 of the poisonous little packets in my detergent cupboard.
I'll use up and not replace some brands (Arm & Hammer; Dynamo; Gain; Kirkland Signature (Costco); Oxi-Clean; Purex;) and keep my three favorites: Tide Ocean Mist Scent; Wisk Deep Clean; All with Oxi. Oh, and Nellie's. I use Nellie's for bath linens. Leaves no scent whatsoever rinses out completely, even in very soft water.
The Kirkland Signature pods clean well, but I'm not crazy about the scent. The other brands are middle-of-the-pack cleaners. Tide Ocean Mist Scent is heavenly.
[this post was last edited: 10/19/2014-18:47]
Alright Frig, seek help!
I know you dig pods, but 300 of them at one time?
I see eerie parallels to IOTBS here........IIRC there were "hundreds" of those things in a truck heading out of Santa Mira!
I dig A&H (best bang for the buck and it is low sudsing now) but by gosh, I don't have jugs and jugs of the stuff around!
SITYS..........................I tried......really I did.
I bought a bag or two of every brand I could find just to check them out and before long there were hundreds of them! Safe to say I can cross detergent off the monthly budget for a couple of years, LOL.[this post was last edited: 10/19/2014-19:09]
That was a small load and the Miele threw the pod up from the bottom of the load while it was doing a fill and tumble. For a couple of seconds the drum is dry tumbling. Because it was a light load the pod just got bounced into the door area
The only things I have 300 of at a time are cans of beer and sheets of toiletpaper. Why 300 beers when I only drink 3 a day? The price rollercoasters from $18 to $27. I'm not about to pay half again for the same stuff so I stock up when it's on sale. Gotta wonder who buys it when it's elevated.
Oh but we were talking about pods. Seen their carcasses adhered to the drum of the coinops downstairs. Never in 60 years have I just chunked stuff into a washer and walked away expecting everything will be dandy. My bad, I'm just not average enough for marketing miracles to work for me. I mean, liquid comes with a measure top and powder comes with a measure scoop, how much more convenient does it have to get?
Pods finding their way into the door boot while the first few tumbles seems to be a common problem. Had the same s**t happen just about every other wash. I think my incoming cold water is just too cold to get them dissolved quickly enough.
My "first aid" remedy was to put them into a sock or sleeve or similar. Works well, but lessens the convinience factor.
Also to get perfect results I had to use two pods for a full 5 kg load in hard water which makes the them very expensive compared to liquid detergent.
Unfortunately one pod is only enough for rather small loads in my particular laundry conditions, so I went back normal detergent.
I don't think it's the water temperature. The machine lodged the pod on the door seal before the water had even really gotten a chance to enter the drum.
I think the machines are designed to their solid items onto the door boot. That's where buttons and other lost items usually end up.
Many washers do initial tumbles to sense the load size - or as a child safety routine like Whirlpool's US washers. In that case, it doesn't really seem to matter where you put the pod because it will end up somewhere else before the water even comes on. I haven't had a problem with pods getting stuck; then again, my washer has a tilted drum.
