Wilkinson Service Galaxy Wringer
brisnat81
May 5, 2004
2,244
Brisbane Australia
Hi Guys,
We went out into the country this weekend, and spent saturday night at a B&B. We found this in a second hand store about an hour from home, and after some negotiation reduced the highly ridiculous price somewhat.
The machine had a small leak from where the pump connects to the drain pipe. It took some work, but I've built a replacement hose.
Power and Agitate control
This control, you pull up to start the motor, and then twist anticlockwise to start agitation.
When you pull up, it actuates a switch, which is basically the bakelite light switches that were in use in the 50's and 60's.
Front Door and Heater switch
When you flick the switch hiding in the chrome (Switch is also another Aussie bakelight light switch) a 15watt globe light up, and glows through the red lense.
The heater kicks into gear and it took about 15 minutes to heat a full tub of water to 35-40degC.
Water heating with suds.
I kept alternating the agitation and pump whilst heating to try and circulate the water, when you engage the pump, water comes out of the hole in the back right corner of the tub. This creates oodles of suds.
Slgihtly less wet towels come out :)
I discovered the single rinses arent adequate. To do this properly it would appear I'll need double wash tubs and plenty of water.
Look where you poke the hose.
Before you engage the pump, you push the hose into the socket inside the wash bowl.
The big advantage of this, is that you dont need to hook the hose over the edge. While you're washing you can remove it entirely.
That looks like an awesome find. And yes, when using a wringer-type machine, 2 rinses are an absolute must to get rid of all the detergent residue.
What a cool machine
I'd love to see the drain operating.
Kinda Maytagesque with the 4 fin agitator, the skinny agi post and the square tub.
I can't tell what the pretty tub is made of, so shiney and smooth.
Thank You-- Wringers Rule !!
Heater
does anyone know if any american washer has a heater function..I know we have dish washers that heat their own water but I've never heard of a wahsing machine that does. I would think the water would get hotter than heating in the maching rather than pulling from the tank.
Servis Superheat
Wow Nathan
Well done on finding such a super machine, and in such great condition, the colour is just subtley different from the UK version..
This model was the Model M over here, produced from 1951, I love the way the front door pulls open revealing the space for the wringer, pipes and the usual "WashTongs"
The Pump is very forceful as I found out when I was filming it, had forgotten to put the pipe in and it shot across the tub and over the top hitting the back wall of the laundry room soaking me and everything else at the same time...LOL
Nathan, what is the turquoise bottle next to the powder,?? it looks very much like Comfort fabric conditioner from the 70`s
Enjoy, Mike
The Turquoise bottle
Is OmoMatic, Frontloader liquid detergent.
Michael accidentally bought 5 bottles of the stuff, and as the Miele doesnt have a liquid detergent dispensor, I have no way of using it.
Its amazing how much Water the tiny pump manages to move. Its only about the size of an orange, yet it moves as much water as a modern pump manages to.
