Window Air Conditioner Advice/Suggestions
rp2813
Jun 16, 2006
18,067
Sannazay
I decided to replace the portable AC unit in my bedroom with a window type in order to gain more floor space and easier access to the closet. The portable is a Soleus 9K BTU that has been a fine, quiet performer for the past two years, but suddenly after never being necessary, it had to have its condensate tank emptied twice in less than two weeks, so I decided this could be an indication of a bigger problem and that it would be a good time to make the switch to a window unit. I paid $50 for it so definitely got my money's worth.
I found a Panasonic model CWXC85HU (see image below), which the seller told me was the quietest window AC available when it was purchased new. I like its simple remote and the fact that unit isn't
"smart" and doesn't have any app nonsense. It blows cold as ice and cools the room down quickly, but it vibrates loud enough to be heard in most other parts of the house. I've tried to fashion isolators for it, but the rhythmic vibration remains and plastic parts on the front of the unit (intake and output grilles) often rattle loudly. Any respite is brief, and it seems like the compressor's vibration fluctuates during the course of operation for long periods, which once again makes both the vibration and the rattling even louder, and it's impossible to sleep. Adjusting the leveling screws on the outside hasn't helped. Currently, a folded up business card shoved between the bottom front of the unit and the inside window ledge is helping with the rattling, but the vibration level is still too much and I'm sure this band-aid is tenuous. I'm wondering if the compressor has a bad isolator. If anyone is familiar with this series of Panasonic, I'd welcome some advice on what to try next, but am not so sure I want to extract the cooling system from its casing in an attempt to resolve the trouble, either.
I've done some searching on line and it seems the Panasonic's 7.8K BTU is more than I need. The new(er) LG 5K-6K BTU window units are said to be the quietest. My sister has an older Toshiba in her guest room and it's fairly quiet. Midea's units all seem to develop issues (mold in particular) quickly. I've always been pleased with any Panasonic product I've owned, but this AC unit is intolerable. I do know that the extra space and easier closet access has already made a window unit preferable to a portable. I'm willing to buy new if that's what it will take to allow for a peaceful night's sleep.
    49 KB
Get some adhesive "closed cell" foam weather stripping, perhaps a 1/2 inch wide, a 1//4 inch thick and run a strip of it on the underside of the unit where it sits on the window sill.
Also a strip on the top flange that touches against the closed window.
That should reduce noise.
Thanks Matt. I had thought about both of those spots, as I had already used some "bubble" type of gasket material that has no foam core on the plastic intake grille with borderline results. There's also what appears to be fuzzy velcro stripping on the underside of the unit just inside the window opening, which seems useless to me, but it was already on there, so I Ieft it. This unit came out of a large Victorian home that IIRC still had original wood sash windows. Mine are '80s vintage metal single hung type which are not as thick as wood, or as forgiving.
You advised to use the stripping on the window sill, so I assume that means the exterior side. I'm fairly certain 1/4" isn't thick enough for that application, but it would probably work for where that velcro-like stuff is currently not doing the job. I'll get some of the closed cell stripping and see how it goes. Maybe not until this weekend. I'll post results here.
I have a 30 year old Frigidaire I put in the bedroom window and this year it was only on 8 nights. Its already out and put away for the winter. People say buy a new one, why? It still runs right and cools and dehumidifies. It may cost a little more to run but its alot less than buying some new piece of junk that may last a few years, at best..
Yeah!
My bedroom unit, an 8,000BTU GE is now 15 years old and still purrs fine.
Come next month I'll store it on the floor of one of the bedroom's closets.
Forget what "people say", I do.
People like to intimidate you and make you feel that you "need" to upgrade, just because they've "bought into" the marketing hype.
Screw that!
Most any window A/C will be noisy to some extent. There are some new U-shaped ones that are marketed to be very quiet, but who knows until you buy one and install it. Often, the construction of your wall and window installation can affect the way vibration is transmitted and made worse. Panasonic is usually one of the quieter brands, and has been very high quality over the years... GE made a "Slumberline" I think, all copper sealed system, glass reinforced plastic housing so it never rusted out, and they were exceptionally quiet. Unfortunately, they were built in the 1970's, so the odds of finding one that's still functional are slim. They were also quite efficient, don't believe the marketing nonsense that you "need a new model" because "all the old stuff is horridly inefficient". They had an EER of about 10, which is difficult to beat even these days. If you can afford it and own the home, I like Mini-splits. There are finally some reasonably priced ones on Amazon, I've brought all mine home from Mexico, a 12,000 heat pump costs around $325. Sounds like you don't need more than about 9,000btus, so if you go that route, get an "inverter" model that will throttle back when the heat load is low. Portable A/Cs are notoriously inefficient, because single hose models exhaust more air from the room than they actually cool, pulling makeup air from somewhere else in the building. Even double hose units can pull some room air out the vent, and most of those are 12,000-14,000btu. You were probably getting about 6,000btu of useful cooling effect from your old one.
My house has a central heat/AC system, but I see no point in cooling the whole house in order to maintain a comfortable sleeping temperature in my bedroom, so that's where the window unit comes into play. I agree with all comments above regarding not buying new. The last thing I want is any appliance that requires an app or is in any way app-friendly (which means annoying update friendly as well), and I have zero confidence in the longevity of anything on the market today. I like this Panasonic and have faith that I can reduce the vibration with the recommended closed cell weather stripping.
My bedroom is on the small side, but big enough to fit my king size bed and some furniture, however the clearance between the window and bed is tight, hence my preference for a traditional window unit as opposed to the saddle type, which would protrude too far and interfere with the closet door, though not to the degree the portable did.
Here's the latest:
I got some MD brand closed cell weather stripping -- 1" wide by 3/4" thick -- and placed it between the top flange and the bottom edge of the closed window. I did this by myself and wasn't able to fit more stripping underneath, but the machine did quiet down dramatically. As time passed over the weekend, the vibration and rattling returned, but weren't quite as bad as before. I assume this is about the stripping gradually compressing just enough to diminish its effect. Also, there's a lip on top of the flange, so the stripping was just barely thick enough to prevent the metal-on-metal contact. I may add another strip to what's already there.
Now that my housemate is back from his long weekend getaway, he can help with keeping the machine raised enough to get a length of stripping under it. I think that will really help. After hearing just how quietly this unit can be, I'm determined to silence it further.
Here's the latest:
Good deal!
I'm glad you have a handle on the issue.
I've had to do the same thing on my window units too.
Here's the latest:
Glad it worked, but if you have central air, I'd use that. Window units are always too loud to run when trying to sleep in the same room. Plus cooling the whole house keeps the bedroom cooler at night.
I used to cool the whole house with a 8,000 BTU LG, I blew it's output at the door, and set a fan in the hall to blow it through the house. It actually worked, kept the house at 71 or 72. But it didn't remove humidity as well at the opposite end of the house. I had to turn it on when I got up, and let it run all day to cool the house until bedtime, and shut it off. Raised my electric bill $80 to $100 a month in the summer.
When we got a new furnace 9 years ago, we also added A/C. It works so much better. On a 95 degree day, it will run maybe three times a day, for a little over an hour. Set at 69. I would drop the temp to 67 or 68 an hour before bed, and it usually doesn't even come on until 3 to 5pm on really hot days. And humidity in the whole house is 40 to 50 percent.
My summer electric bill are now $10 higher than in the winter. Maybe $20 higher than the couple months where we run no heat or air. That blower fan uses energy in heat mode too.
Since you have both, experiment and see. Insulation and sealing are important too, until we did that, and added R58 to the attic, the window unit could only cool one room.
I would suggest that the rubber compressor vibration isolators have likely gotten hard, as surmised in the first post. Replacing those with some nice soft ones, perhaps something from McMaster-Carr or the like, ought to make a world of difference, isolating the vibration at its source.
I have a 5k Panasonic from around ‘02 that is extremely quiet. The sound it does make is pleasant and soothing for good sleep. I modified it with a switch such that I can have the fan cycle with the compressor when desired. It’s a nice feature.
As with most products of this nature, older is definitely better. Mine isn’t old enough that I would consider it to be exceptional, but I’m sure it is better than anything currently available. Go far enough back to where the machine and everything in it is made in the USA and not Asia and you get in to the really well made stuff. They require- and have earned- TLC, but it’s definitely worth it.
All of these have an Energy Efficiency Ratio around 9 or so, so the idea that getting a good one is going to cost more in electricity is a lie, just as it is with old refrigerators.
Keith
Thanks Keith. I'm down with everything you stated above, but as much as I'd like to replace the compressor isolators, that's more than I want to take on, and besides, the machine operated almost silently for a while after installing the more durable weather stripping. Today I'm going to have my housemate help me add more stripping on the underside and another layer of it on the top flange. I noticed after the unit went back to its old ways, though not nearly as bad, the furthest window from the one where the AC is mounted was making a bit of noise from the vibration (the windows on the exterior wall are configured in a triptych type of placement). I feel like adding a length of the thick weather stripping on the underside will eliminate the vibration that's having far-reaching effects.
I do trust that this Panasonic will again be the quiet machine it was designed to be, and last longer than the portable it is replacing. I'm not one to give up this sort of thing easily. As for the suggestion to run the central AC 24/7, I can't imagine such a thing penciling out. The house was built in 1922 and has no insulation. My street is unusually wide (a long gone trolley ran on it) and the original street trees that provided shade are nearly all gone, replaced with smaller ones, so I'm in a heat island with west-facing original architectural windows on the front that would cost a fortune to replace. The rest of the windows were replaced with metal single-hung, single pane ones probably 35-40 years ago. With the summer sun beating on the front of the house from early afternoon until nearly sunset, the house heats up quickly even on days when temperatures only reach the low 80s, and the central system kicks in. Summer nights are generally cool and comfortable, and that's when window fans cool off the kitchen and living areas, and the central system's fan-only setting circulates things until bed time. There are very few instances where this isn't enough to keep things comfortable in the rest of the house. Since I find 65 degrees to be the ideal sleeping temperature, I can't see cooling the rest of the house down to match that.
House built in 1922, that is so cool.
Might think about some good quality heat rejecting film for the south / west facing windows I suppose.
I agree- it is definitely nice to be able to get the bedroom nice and cool independently of the rest of the house for good sleep. Sounds like this unit will ultimately work out well.
Many of those portables- ie the ones that have only the one exhaust hose- are pretty inefficient in that they are drawing your conditioned room air out and using it to cool the condenser. This also creates a negative pressure in the building, so dust and the like is being drawn in along with warm and humid outside air. The window A/C is a considerable upgrade. 👍
Keith
Having no insulation will definitely make a difference. Window or central AC. You may want to remedy that. Mine was built in 1975, but there was only about 3" of insulation in the attic. It didn't even cover the 2"x4" truss bottoms. Later new windows, house wrap, sealing, etc. Heating cost dropped about 40%.
They just didn't think about those things back then. That's why the window unit could only cool one room at that time. And I didn't know anyone in Northern Michigan that had A/C back then either. Now it's pretty standard.
Thanks for the additional comments and input.
My housemate is leaving town tomorrow and has been chasing around, so I'm hoping we can tend to the Panasonic within the next couple of hours.
Keith, I've attached a shot of the house as it looked when we bought it in 2018. It's an undocumented Wolfe & Higgins (or possible knock-off) in a neighborhood where documented examples of that architectural team's work are still standing. I don't even want to think about how much it would cost to replace the street-facing windows, and I doubt they would do the original ones justice. We're currently in the final stages of a complete overhaul of the front yard with drought tolerant plants, palms, berms with large rockery, and no lawn to be watering on a way-too-frequent basis.
    43 KB
That sure looks like a neat old house.
Interestingly enough, we once lived in a house built in 1968, also with no wall insulation. It does make a difference, of course, but not as much as one might expect.
The previous owner had replaced the original metal single pane windows with plastic double pane windows that also sealed very well. They were ugly, but worked well.
Furthermore, when I replaced the flooring I caulked and air sealed completely around the base of every wall, even the interior ones.
The result was that the house actually stayed comfortable fairly economically.
There probably is nothing made today that could replace the beautiful original craftsmanship of your original windows, and if there was, it would have to be very expensive.
But air sealing is often a place where there are a lot of gains to be had. Cutting down on air just leaking in and out of the building makes the biggest difference.
Keith
Attic insulation is the most important, and easiest to add. And as you say, sealing and windows.
Heat rises in the winter, and the sun beats down on the roof in the summer. Like I said, I lowered my heating use by 40%, that's a huge gain
I can't even fit through the attic access point in one of the bedroom closets. I'm pretty sure it hasn't been insulated, but only a small person could get up in there to check. There are definitely a few draft points; all three doors to the outside and one window that's having an "unscheduled disassembly" as they say at Space-X. I have weather stripped the doors, but I still use rolled up towels across the bottom of two of them during the winter. I've lived in some drafty houses and this one seems remarkably tight otherwise, considering its age. The hardwood floors are original, but when the previous owner re-did the kitchen and main bathroom with tile flooring, I think they may have sealed those areas. No shortage of projects for permanent solutions, that's for sure.
As for the Panasonic, the underside got weatherstripped and I added another layer of it to the flange on top. That got rid of the various rattles, but the rhythmic resonating is still present, although reduced to a tolerable level. I'm sure at this point that the compressor isolators are the problem, but it's not bad enough to interfere with sleep, so I'm calling it good.
I built half my house. Added a 360 sq ft addition, plus a 2.5 car attached garage. Other than the foundation, I did all the work myself, except the insulation. Even though I can get in mine, it's in a closet like yours, with a separate garage hatch.
Blown in insulation is a mess, I hired that out. As far as checking, you don't have to actually go up there, just look through the hatch. You'll see if there is insulation or not. Mine's 18 inches deep, can't miss it. And I'll never go up there again now.
I hadn't thought of it until you described it, but this is often a characteristic of single phase compressors. It might be worth checking the value of the compressor run capacitor, as the run capacitor more or less mitigates this effect. Depending on the design of the start circuit, it may start and run just fine, even if the capacitor has failed completely open.
Agree, this is very true. That house I described did indeed have pretty good attic insulation, and I did add more to it as well.
Keith
I absolutely hate blown in insulation. My house had the cellulose kind, and the attic looked like there had been a blizzard of gray snow. After a problem with the air conditioner drain, I had to use a coal shovel and scoop up an area at least 10'x12' - not fun on a hot day. I had a company vacuum out the rest. Firefighters despise the stuff when they have to pull down a ceiling to extinguish an attic fire. My friend Fred says it comes down like a avalanche, and gets on everything, especially their turnout gear. I much prefer mineral fiber batts.
That's why I said I'll never go up there again. Too messy and dusty. And there is no reason to go back up there.
My HVAC is in the basement, at our cottage it's in a closet. I think HVAC in the attic is one of the worst idea I have ever seen. Yes it's hot up there (or freezing in the winter, it's horrible for efficiency, running the system and ducts (usually flex) up there.
Metal ducts inside the conditioned area is the way to go. Any heat or cooling loss is in the house, not the attic.
Yes, I certainly agree an attic is an undesirable place for HVAC equipment. In addition to the insulation getting wet, the air handler and flex duct got contaminated with mold, necessitating its removal.
My place had about 5" blown in when it was built around 1966, which has settled to maybe 3", with a quarter inch of desert dust on top. I detest the stuff, but it would be really difficult to use much else... I once was installing an attic fan and climbed up into the cupola using a few 1x4 steps that had been nailed to the truss'. One failed, and fortunately for me, my arms went behind the remaining one, so I was only in the dining room below the waist... still finding that pink shit in boxes that were there at the time! The scrapes on my arms and chest were nothing compared to the broken leg(s) I'd likely have suffered if I'd hit the concrete floor.
Keith, I've heard compressors on refrigerators make a similar rhythmic resonating sound and always felt it wasn't an indication of imminent failure, so thanks for confirming. Since the monsoonal humidity cleared out yesterday, it cooled down quickly last night. I used the fan-only setting on the Panasonic and noticed on medium speed, the motor makes a similar sound, but it's more like a rhythmic hum. It's just the nature of some electric motors (those used in most mid- to low-priced ceiling fans are a good example), in my amateur opinion. On high speed, the whooshing of the air flow and perhaps increased RPM combine to reduce the hum to an unnoticeable level and I'm OK with that.
Meanwhile, I've been meaning to poke my head up into the attic and do a 360 sweep with a bright LED work lamp. The living room has a high barrel ceiling so I'm curious to see what amount of clearance for insulation there is. I have a feeling batts would be the best way to do it, but I'll leave that up to the pros when the time comes. I don't see any of the tell-tale exterior stucco patches that indicate insulation was ever blown in, so am fairly certain there's none in the walls or attic.
The first house we bought (in 1990) was completed in 1957. At some point in the '70s or '80s, insulation was blown in. We didn't have central AC and got by with a couple of fans. This was in an area of town with a lot less marine influence that rarely received cooling from evening breezes during hot spells. It seemed to me that the insulation worked against our attempts to cool things down with outside air at night, instead retaining the day's heat inside the house. Since the current house has central AC, insulation makes more sense now.
About the rhythmic hum in compressors- To try to explain simply- the single phase alternating current supply is delivering power to the motor in pulses (120 times per second, here in North America). The compressor is taking power from the motor, typically once per revolution.
Since the motor is an induction motor, it runs a bit slower than the line frequency, and so the two events slip in and out of phase with one another.
At times the power delivered from the line coincides with the compressor taking power from the motor, and the unit is smooth and quiet.
In between these times, the compressor is taking power from the motor while power is not delivered to it, alternating with power delivered to the motor, when the compressor is not taking power from the motor. This results in vibration.
The difference in the speed associated with the line frequency (known as synchronous speed) and motor running speed is called slip, and it is a frequency usually in the low single digits, around 2 or 3 cycles per second.
It doesn't indicate any trouble with the machine, it is merely a characteristic.
A motor with a run capacitor delivers a more steady torque to the motor, and so they can be smoother and quieter. If the capacitor is weak or failed, the machine might make more noise than usual.
Keith
Thanks Keith. I felt fairly certain that alternating current had something to do with it, so I appreciate your explanation.
Another curious thing is that depending on where you are in the bedroom, the resonance isn't present. This includes directly in front of the machine, where it's nearly silent, but step away in any direction and the rhythm returns, only to disappear when you're standing by the far side of the bed, where it gets quiet again. I think the machine is settling into the additional weatherstripping, as I've been running it for several minutes at a time to do noise checks. So far, noise level has stayed the same and no new rattles develop after start-up, which was a problem before. Fingers crossed that no more tweaking will be necessary.
