Would you buy an handmade washing machine?
Well, I suppose it would be better than beating clothes on a rock at the riverside. But who’s gonna have the strength to haul that heavy, wet carpet outta the washing machine tub, wring it out, even with a hand wringer that would be a BIG job, then you’d have to empty the tub, refill with rinse water and then wring it out again.
If the machine had an attached, powered wringer then this would be a great basic washing machine for people that were very poor and had no hookups for an automatic washing machine.
But that being said I admire their ingenuity.
Eddie
Well, I suppose it would be better than beating clothes on a rock at the riverside. But who’s gonna have the strength to haul that heavy, wet carpet outta the washing machine tub, wring it out, even with a hand wringer that would be a BIG job, then you’d have to empty the tub, refill with was water and then wring it out again.
Eddie
most of pakistan is desertic so their clothing is probably light but yeah drying a heavy blanket washed in that machine is tough, but as you said better that washing it in una tub by hand
Wow, talk about a simple design! That machine makes my late 30’s Maytag wringer washer look downright complicated! It’s fascinating, seeing those materials go from rolls of steel and a pile of hardware to a fully functioning washing machine in a matter of minutes. Thanks for sharing!
ea56…
I agree, I think that the #1 improvement to be made to this machine would be either a power wringer, or a twin tub setup like the Easy Spindrier. Heck, maybe they could even sell a separate stand alone spin drier to go with it. I also think it’d be cool if they put a dishwasher type heating element in the bottom of the tub to make hot water washes easier, and added an electric drain pump. If they did a drain pump, maybe they could even have an option for it to run in reverse and have a recirculating lint filter.
Thatwasherguy.
I found this online - it's their Super Deluxe model! 😮
It even has a top control panel!
And I gotta love the cardboard "padding" inside the cabinet.
Now THAT'S Quality Design!...... Maytag!..... eat your hearts out!:ninja:
That's why the motor is mounted on a piece of wood and not on metal
Is that what the makers of that contraption actually said?
And when that hunk of bare wood gets weakened by moisture and warps, then what?
Has any proper grounding been implimented?... I doubt it.
Here in America we have strict electrical codes, and would not permit such a thing.
Strict? I can still get heaters and toaster ovens without an equipment ground. :p
ea56…
Thatwasherguy.
Personally I would at least want an electric drain pump, water valve and automatic cycle timer.
Basically have it fill, wash, drain, fill, rinse, drain, fill, rinse, drain.
Next model up would have a spin cycle.
In any case these models are better than nothing and for those washing in buckets these do make the wash portion a lot quicker and easier.
I can see a wife wearing those sandels standing on a splashed up wet dirt floor in some shack holding that machine still, and what kind of leaked voltage might tingle her toes.
"Underwriters Laboratories Approved"
The outlets over there tend to have 30ma RCD protection.
However, In all fairness those washers really do need an equipment ground.
Tend?
I'm sure, like anywhere, those protection devices are not mandated or inspected.
Someone I know from Vietnam told me that at night, the power lines were tapped into to "steal" power so people could use their devices.
Tend?
Key word. They are often mandated, but enforcement is rather something else.
I still admire the passion and entrepreneurial nature of these manufacturing places. It is the start of capitalism and how people and a nation are lifted out of poverty.
I bet the washing performance and reliability are better than 90% of current US top loaders.
You see it!
If US manufacturers with their knowledge, tools, experience and resources had the freedom and charisma that these cowboys had they would be able to produce a washing machine that out cleans any combo or direct drive ever produced while lasting 60+ years. It is why I have so much respect because the rogue manufacturers are the seeds to the appliance renaissance.
Watching the video, they're cutting the tub with shears out of thin flexable sheet metal - looks like roof flashing, and easily dented if you watch them insert the drain hose on the bottom.
The supports are simple angle steel too.
How can that tub hold up over time? Being exposed to the weight of gallons of water and clothes swishing around.
The outer cabinets are also thin sheet metal.
The one guy picks the whole machine up with one arm.
Now compare the washers made here with the heavy porcelain coated tubs.
Sorry, I give those guys credit for trying to make such a product, but it's a sad replica of a factory produced machine.
At least the tub is metal and not plastic like the outer tubs in virtually everything else today except Speed Queen.
That agitator and its 180 degree wash action is reminiscent of old school washers and is definitely better than just about anything today. Transmission probably overbuilt compared to today's under designed junk. The cherry on top is the lack of a pestering VM groan or the clickty clack of a DD in its wash action. Full control of the water level. No control board to shit the bed in 1 year, costing half the original price of the machine when new...on back order or obsoleted. No junky suspension rods that need replacing on a regular basis. No plastic splutch or crappy underdesigned mode shifter to strip or die. No agitator dogs that need replacing. No snubers to grease or replace. No water pump to die. No lid lock or lid switch to replace. No water valve to replace. Only a couple of seals and a hose to potentially leak water. Simple, easy tear down and repairs.
I'll still take this.
Yup, well said.
The thing is, if you stuck a pump on top of the motor (which is already capable of reversing), added a direction activated neutral gear in the transmission, pressure switch, fill valve and EM timer you'd have a fully automatic washer minus the lack of spin.
And given the lack of suspension, outer tub, clutch, brake and basket drive a relatively compact machine can fit a full size load of laundry.
For some folks that is way better than doing laundry in a sink or bucket.
