WP Dishwasher questions
Installing a 70s whirlpool convertible dishwasher
It’s pretty straightforward but you leave the cabinet on the machine. you remove the top and the wheels as usual then you end up drilling holes through the sides of the cabinet to run water, lines, electric, etc. in most cases
Leaving the cabinet on actually makes it a little bit bigger machine, so if the spaces tight for your existing built-in, it may not fit check it out carefully.
John
