Wringer washer typical cord length
2011hoovermatic
May 1, 2011
55
owosso michigan
Hi I've on and off used my kenmore wringer washer and would love to know how long of a cord was typical on any of them so I know how long I want my next cord to put on it.
Thank you.
2011hoovermatic VL 2011hoover700
To best of one's knowledge power cords for wringer washers were pretty generic. That is same ones were used across line of automatic and semi-automatic (such as wringer washers).
For grounded plugs Maytag part number for wringer washers is WP204590. That cord fits vast range of Maytag and now every other brand of washer under WP's umbrella.
https://www.amresupply.com/part/WP204590
https://www.maytagreplacementparts....CSCAW-Maytag-Washing-Machine-Power-Cord-Parts
Would be very surprised if Kenmore Sears (Whirlpool built) were not same indeed as are every other semi or fully automatic washer. That is a generic off shelf power cord.
Depending upon age your machine either will have two prong (ungrounded) or three prong (grounded) cord. Latter is more safe and connecting ground wire isn't difficult even if there isn't a spot for it on machine.
Length either will be what you can get off shelf or want to be if choose to make a cord yourself.
Above all being said as with many other semi-automatic washers power cord for wringers may be a tad more generous in length compared to automatic machines. This to allow for fact since semi-automatic washers were portable and needed to be moved near source of water and sink/drain a power outlet might not be close hence need for bit longer cord.
