John -
You can't defeat the lid switch permanently unless you install a toggle switch inline with the lid switch, as Glenn here did. The washer needs the lid (and switch) to open at the end of a cycle before it will allow you to start another cycle. So be careful of that. In the meantime, if you want to watch any time, you can reach under the right rear part of the the top of the washer, past the rubber gaskets and feel around under there for the switch (right rear of the lid). You can feel where the end of the lid makes contact with the switch itself, and just push in on the switch....and your ready to go. Just be very careful not to displace any of the rubber gaskets under there, or you will allow water to splash over the top and down into the base of the machine, causing rust problems. If you raise the top of the machine itself, make certain to replace the rubber gaskets in the proper place - they slide along the underside of the lid and are easily displaced.
I've had mine for 8 years this January, and it still works like a charm....does a nice job cleaning too.
