yeah another Haier post story but good
bpetersxx
Jun 6, 2008
1,810
laf in on the banks of the Wabash River
This is about my Haier xqb60-91bf top load impeller washer
This one was used and abused to an extent
It came from Ebay
Did the normal checks on it and it spun weird
I checked the bottom and found the bolts the hold the guts tight were very loose
That caused another problem the inner tub wore a hole in the outer tub at the top of the outer tub where the tub ring is
That caused it to leak if you used max water level the water would slosh out the hole in the top
So I tightened the bolts and caulked the hole in the outer tub
now it runs like it should
washes great does not suds-lock drains great because I had to put a gray generic hose on it water gushes out when draining
But I think it may be aggressive on washing because the lint filter clogs and it squirts around the connection to the top of the inner tub
I have to scrape the lint out
maybe some of the fine members here can shed light on this
Oh it has a waterfall washing action as well
