Your Favorite Dryer
My grandmothers both had early Maytag Halo-of-Heat dryers (DG701 and DE500). They WERE eerily quiet. Those dryers were SO overbuilt. The sad thing was, IMHO, the later 06-series dryers were not big enough to properly hold a max size load from the 06-series deep tub washers.
As far as modern dryers go, I have a Maytag "stream-of-heat", the top part of my SE1000 stack. It does a fine job of drying on its default dryness level. It's a bit on the wee side, but the service manual says the drum volume is the same as the HoH dryers, so its a fine match for the standard tub washer.
I've really admired the WP/KM dryers I've had for their massive capacity and speedy drying, but as others have said, they don't do well on small loads. Perhaps Maytag was on to something back when they put the sensors on the drum baffles. I've also never cared for top-mount lint filters. They just guarantee a nice lint-dust coating on the top of the dryer, washer, and anything else nearby. I also don't care for filters that don't come out of the machine (or don't easily come out).
As a child, we had a 1973 Speed Queen dryer that seemed to have the ideal lint filter. It was a large round screen (18"?) that slid out of a holder in the door--no stooping, and you could carry it to a trashcan and clean it there. Come to think of it, that really was an ideal dryer--stainless steel drum and and the gas valve was under a lid in the top of the machine--very easy to relight the pilot. I remember it was quite a chore to relight the pilot on the HoH gas dryers, since the pilot light itself was far to the left of the access panel. I remember dad fashioned a "roach clip" type thing to hold the match (that's all it was used for...). In retrospect, maybe if we had made sure the flapper on our exhaust hood was operating correctly, the pilot light would have stayed lit. Ah well.
T.
Maytag dryer
Rinso, Thanks for the input, and it is interesting on how Maytag set up there electronic sensor control and how it functions. But I would have thought that Maytag would have improved on this design when they redesigned their dryers and dropped the Halo of Heat design. The Maytag(DE608)I have was redesigned from the Halo of Heat dryers and was marketed as Maytag's "Big Load" dryer with the heat flowing from the back of the drum to the front and exhausting out just to the left of the drum opening. The electronic sensor is located below the door opening and looks very similar to the whirlpool design in the way is senses moisture in the clothing. Also, the model I have does offer a choice of low heat, reg heat, normal dry or for that extra heavy load Extra dry. But no interior light which would of been nice, but as we all know Maytag only offered that on their top of the line model. Don't get me wrong I like the dryer, and and its matching mate washer and I am glad to have gotten them since they are last of the center dial machines. But in my opinion I think the dryer is slow in responding to the load being dry and as a result I think it overdrys things. So to overcome that shortcoming, I just set a timer in the kitchen that goes off in 30 minutes to remind me to check the load.
Yes, when Maytag re-desgned their dryers with larger drums and an up front lint screen, they implemented models with an electronic sensor which functioned similar to other dryers. They also offered a "time and temperature" auto dry in their lower priced units for a few years. The halo of heat design was noted for being very gentle, but I suspect it was more because the dryers had no temperature selection options and didn't really get all that hot. The tiny drums were way behind the competition's offerings and I was glad to see them go, although the dryers were very well designed, constructed, and reliable.
Maytag Press care--
runs for about 20 minutes, and chimes several times. Sometimes, I will run a non-perma press load in the cycle, just to hear the chime.
Lawrence/Maytagbear
I remember that cheery little chime on the perma-press cycle. A real bell and not an irritating electronic whistle or buzzer...Although coupled with the lighted panel, the whole thing at times remembed me of a pin ball machine.
The Vented Frigidaires if the 70's!
Loved the vented Frigidaire dryers of the 70's. Big lint screen on the door, and electronic sensor in the center rear of the drum so that clothes continually came in contact with it. Also had a lever that could be turned to stop the drum from tumbling so that the rack could be installed for drying ball caps, (no not that kind!) sneakers, and sweaters. Had a wonderful interior light and a sprinkler feature so that clothes that needed it, were ready to iron! Second choice would be the 1-18 dryer. You could fit large comforters etc in that machine and everything came out consistantly dry. Mark
My vote-Kitchenaid
I have to agree with Greg-The older Kitchenaids with the window on the door really rock. They are that rock solid Whirlpool design that oh-so-easy to repair and maintain. I love the hamper style door(though I realize not everyone does) and KA's have a porcelain top. I too, am not so crazy about the top mounted lint filter, as it leaves lint all over the top of the machine. On my particular tropical island, one is usually faced with wiping all the gecko poop off the dryer anyway, so whats a little lint?
I do like the pretty chime on the Maytag over those annoying buzzers that can scare the bejesus out of you.
Any of the large capacity Whirlpool/Kenmore dryers would work fine for me...especially with the hamper door!
David, I've pretty much become "immune" to the Kenmore's end-of-cycle buzzer, but the fabric softener signal on the Dual-Tumble is twice as loud and will scare the s*** out of someone if they're caught off guard!
My mistake
I once made the mistake of buying a Maytag MDG9420aww because it was a "special edition" with the old time cursive "Maytag" logo on it. Thats the only reason I bought it. It did not have a way to shut the cycle signal off. Its not that it was so loud, just that it would catch you off guard if you were down the basement doing something else. More than once I darn near "pit my shants" when that buzzer went off
I don't have a favorite dryer. Is there something wrong with me? I mean, I've never erally be overly excited with any of the dryers in our family. Two Norges, 2 big-mouth GEs, a Kenmore, and now my Matag. None really light my jets.
I do like my Maytag Dependable care with the moisture monitor. It's fun to watch in the dark utility room.
My ideal dryer would be a 29" WP produced dryer with electronic sensor, infinite temps (inlcluding air on the temp knob); huge drum; and side-swing door.
Bob, were the Norge dryers you had the "lint-blower" design?
How was this design different from the other dryer designs around at the time?
electronic drying sensors
"Thermostatic/mechanical auto dry- (where the timer only advancs when the heat is off). I hate the electronic ones. Other than newer Maytags I always had wet clothes at the end of the cycle, especially with partial loads!"
I find that the sensor on my 78 LK works perfectly for ALMOST everything. I've learned the exceptions over the years, which seem to consist of two circumstances.
Heavy cotton items like with thick seams and such have to be set one degree higher on the dryness control.
Synthetics like polyester, nylon, etc., need to be set to Maximum Dry.
Sorting of the clothes is critical, too. Light cottons like sheets, trousers, shirts, boxer shorts should be dried together.
Likewise heavy cottons like jeans, towels, heavy cotton underwear like T shirts and briefs.
And, of course, synthetics should go together.
Mix those itmes and it confuses the sensot and causes over or underdrying, depending on the mix of materials.
Follow those sorting and setting rules, and the automatic sensor will stoop at exactly the right time almost always.
Incidentally, the early KM electronic dryers had the sensors on the baffles like the Maytags
Steve here is a picture...
Kithchen Aid Dryer KGYW778B with a glass window. It has a push to start button that also turns to control the drum light (Off/On) in case you want the light on while you're drying.
That looks really like an oven! (at least from a european perspective anyway)
It's taken me at bit of time to think up my most favorite feature on a dryer. It could be the clothes damping disc that mom got with her 1963 Maytag. You'd fill it with water and it attached on the center back of the drum where the lint filter snapped in. Then there was the hair dryer attachment you could get for Norge/Wards dryers. I'm guessing that those who used it ended up with a hair full of lint, but I guess you could just pass it off as a bad streak job. Oh, I know, I loved the reverse tumbling that Gallery dryers had for a while. At first I thought it was a stupid idea, but it really did help un-ball large items like big comforters or bedspreads.
Re: Kitchen Aid Dryer's with Window:
Hi! Jeff, thank you for sharing the Pix's of the Kitchen Aid Dryer's with the Windows. What year are these Washers and Dryers, I've never seen them ever before, but I've seen the Windows in the Unitized Whirlpool Larger Capacity Top-Load Washer, with the Dryer Stacked on top, with the same Rectangle Window.
Peace and Happy Kitchen Aid Drying, Steve
SactoTeddyBear...
sorting
Nothing is perfect, and those exceptions are few. Actually, that's the way things should be sorted even going into the washer, IMHO
INTUITIVE DRYER
Definatly the intuitive dryer. it is sooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo cool!
For those not aware the "Intuitive Dryer" is F&P's SmartLoad version now marketed in NZ/Aus. The control panel is redesigned to match the IWL12 washer instead of the GWL11, and there are several additional pre-programmed cycles similar to the Lifecycles on the IWL12.
Old thread
My favorite dryer is the Maytag Halo Of Heat, quiet in operation, gentle (that’s if the venting isn’t restricted along with the lint screen), and fairly easy to service. Wish I had experience with the pre HOH dryers but sadly don’t since I haven’t had any of those style of Maytag dryers come through but heard they dry fairly quickly, though.
