YYYYYYYYYYEEEEEEEEEEEEESSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pulsator
Bronze Member
Jun 30, 2002
2,377
Saint Joseph, MI
My mom did the greatest thing for me, she surprised with plane tickets to go to Clean '05!!!!!!!! I am so excited!!!!!!YYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Interesting.
Your 500# and up machines look like central concrete-mixing plant:-)
What's this "Jamie's washer"? Looks like a 3-tub version of a twin-tub. Wash on the left, spin in the middle, rinse on the right? Could you explain more about this one?
Is there any good case for a normal residential user to buy a commerical machine? For example, as compared to a decent quality residential machine? (Or, get the version with the coinbox, and when your friends come over to do their wash, they can pay for the water & electricity & proportional cost of the equipment?:-)
Jamie's Washer
This is the machine that I am trying to get at work. (I'm Jamie.) To use it you wash the clothes in the two wash compartments and then spin them in the Centrifuge in the middle then after spinning a minute or so it does a spray rinse it the centrifuge. It would be fun to watch a spray rinse at 1,600 RPM! They can last up to two minutes! I think it would be a lot of fun to see this machine in action and because it is semi-automatic I would have an excuse to stay and watch it!
http://pg.photos.yahoo.com/ph/peterh770/detail?.dir=e5ee&.dnm=904a.jpg
Unimac Twin and Double Wash Tub Washers
Those Unimac washers come in two and single wash tub versions, both with centrifuge/rinse tub. Unimac is a commercial divison of Alliance Laundry systems and those washers are sold under their "car wash" line of appliances. IIRC model numbers are 101 and 102. Several have appeared on fleaBay in recent months ranging in condition from brand new to used.
IIRC all require 3 phase 220/240 volt power, but do not need to be bolted down (could be wrong on the last part).
Alliance markets these units for car washes to process lots of rags and mop heads rapidly, but our local laundry says many commercial and hotel laundries use them for doing everything from shirts to linens.
Operation is simple, you wash in the wash tubs, transfer the wet laundry to the spin tub for rinsing/spinning dry. The units have a patented "diffuser" spray that sends a fine mist of water through the laundry during a slow spin, it then ramps up to final spin speed to spin dry. Wash time, rinse and IIRC spin dry times are all user controled by timers.
Have posted several threads regarding these units before, if interested you could check the archives.
Launderess
