@ Rob - nice pics !! here the Formula Inox series never came out with a 1000 rpm model ... can't imagine how noisy they were
I notice that the P 1011 has an interesting "Eco °C" button. Do you know which way does it work ? Like in older Candies where 90--->60 , 60--->40 and 40--->30 °C or like in the Aquamatic where it works only to cut down the boilwash to 60°C ?
@ Al - you're right, Candy are such comedians
. The detergents/LCB/FS compartments don't have separate valves. The dial/timer is connected with a rubber belt that moves a nozzle over the compartements. When the belt gets loose the nozzle "shakes" and detergents,LCB and softener are dispensed all toghether in the first fill
@ NorfolkSouthern . Yesterday I ran a full load in the 2005. I used the same amount of detergent I normally use in the Mieles (these use a quarter of the water while washing compared to the 2005). It made so much suds they overflooded from the drawer. Now I know I'll never use wool detergent in this machine
Anyway, thanks to the high levels and slow spins every programme is perma press in this machine, even @ full load
