launderess
I think 1/2 cup would be way too much for a wringer
That is the amount listed on my vintage (silver foil wrapped) boxes of Calgon water softener. This product would have been around when wringer washing machines along with automatics were in use.
One half cup is not a great amount of Calgon when you consider the addition of phosphates lessened the amount of soap or detergent required. Mind you the half cup was an average dosage given to deal with water hardness across the United States. If one lived in a soft water area you probably could use less. The other standard advice given for using phosphates was to add the amount that gave "slippery" feeling water which remained so.
The other thing to remember is packaged water softeners not only must cope with whatever minerals are in the water, but those that come off soiled laundry as well. Ideally you are going to want some reserves to cope with that lot rather than say having to add more product (or soap/detergent) during the wash cycle.
Your grandmother's method would have horrified (no offence meant) home economists of the period. In essence using soap both to clean and soften water.
Soap on its own will soften water by binding to minerals. However besides being an expensive use of soap it also large amounts are needed both to sequester hard water minerals but to replace the cleaning power lost by soap tied up in that process. The addition of *any* sort of water softener including TSP was preferable to using soap alone to both soften water and for cleaning. [this post was last edited: 7/31/2014-14:09]
