an interesting question about my Bosch dishwasher: if a glass flips DURING the wash, can it detect the water level getting low?
wholelottared
Dec 7, 2022
62
Turkey
because guess what happened today... my huge 600ml water glass that was in the bottom rack must've flipped during the wash because after the program ended it was literally in inverted position and it was filled completely with 600ml of dirty water.
since it's a huge glass, it made me curious about one thing, can the machine detect such cases during the wash and add extra water? because like... 600ml is huge and it must've used the water that normally should've been in circulation during the wash. i don't know during which phase it flipped, but it might be prewash since it had a dirty water.
what happens in these cases? do these machines have anything for dishes that might flip and fill during the wash?
my model code: Serie 8 SMS8YDI82T
thank you so much!!
thank you so much!!
I doubt it. What rack did you have it on?
Some units that sense the fill level via pump motor's current draw claim to have the ability. A more substantial volume of water adjustment may be required to trigger it than may be expected. DishDrawers sense the fill level via that method. Plastic bowls and cups flip occasionally in my DD but the only instance I've clearly noticed it adding more water during a wash period was in response to oversudsing from a Cascade Platinum pod.
Whirlpool built dishwashers can detect the lack of the water and may issue a fault code from an item that flips over or holds water. They will not keep adding water to make up for it, however.
This can cause the water heating function to lock out to prevent possible damage as the machine doesn’t have enough water in it anymore to keep heating the water.
John
It really depends on when it flipped and on which cycle.
The machine does sense cavitation. It has to for safety reasons - if the flow rate would drop to low during a heating phase, it could lead to the thermal fuse blowing on the heater, and these do not have any pressure switch as a sensing fallback.
There are cases where some machines burn out their heaters early because you can only sense so much - especially with sudsy detergents.
But if the flow rate falls during a heating phase it has to react, either stopping heating or adding water.
On some parts of the cycle it definitely doesn't though.
I think once heating is done, it does not care for the main wash.
Interim rinses might care, and the final rinse has to care again.
