Modern front load washers recirculating water over the load
spinspeed
Silver Member
Oct 4, 2009
237
Far North New South Wales Australia (originally Lo
I have 2 LG front load washers. Both spray wash and rinse water over the load throughout the cycle. One has a single spray port, the other has 4 spray ports around the boot. To me it seems like a very sensible efficient addition to the machine and would improve wash performance.
I just spent a lot of money on a new Fisher and Paykel washer / heat pump dryer combo. I am really disappointed it does not recirculate water over the load during the cycle. It just tumbles through a small pool of water in the bottom of the drum. It seems quite old fashioned. I kind of thought all modern front loading machines would have water recirculating over the load these days.
My first front load washer that did this was a Zanussi IZ 1600. I purchased it mid to late 90s I think. It was a fantastic machine and lasted for may years.
I cannot complain about the wash results from the new F & P, it washes really well. It has a massive 18kg drum.
Does the recirculating make much of a difference or is it a bit gimmicky? What other brands have the recirculation design? Interested to hear what other folk think about this.
I suppose there's the angle against recirculation in a frontloader, which is sourced through the tub sump and presumably through the pump trap, for it pulling lint and potential bits of muck from the sump and trap and distributing it through the clothes?
I love the drama of water, splashing on the clothes, being recirculated, and it certainly may help get things wet a little faster when the cycle gets going, my old whirlpool built combos that do the recirculation and are fun to watch for sure.
But as a repair person having an additional pump to recirculate water is a potential problem waiting to happen, the Electrolux full-size front load machines in this country have three water pumps in them. It’s an absurd amount of complication in my opinion.
You also have the problem, especially with modern low water use machines of when you finally get the grit and sand out of the clothing. You don’t want to turn on a pump and dump it back onto the load, just like in dishwashers soil settling is a very real thing and it’s an effective way to get soil out of the wash, water, etc., and then pump it away each time it drains.
By far the best built in most reliable full size front load washer, you can buy in the United States is a Speed Queen and I’m glad they don’t do gimmicks like this. There’s no Wi-Fi connection. There’s no recirculation pumps it just gets the job done beautifully a year after your load after load, my older, Speed Queen is 20 years old never had to do a thing to it. My newer one is just five years old, but I don’t expect I’m ever gonna have a problem with it possibly in my lifetime.
John L
It also slightly changes detergent requirements.
Machines without recirculating systems long had those ball valves closing off the sump during fill so no detergent gets wasted.
That in turn means there is a physical separation between the water in the sump and in the drum. Less water to heat, less water to add detergent to.
The volume in sump, pump and hosing for recirculation is basically always in the realm of only half a gallon or something like that, so it's not much. But it does exist.
A lot of manufacturers took a long time for recirculation.
The main reason it's added is to saturate and distribute water, detergent and other additives quickly.
Every tumble lifts some water in the drum paddles and dumps ot over the load. That's the same as recirculation, just slower. Recirculation does the same, just quicker.
With very high loading ratios (more laundry per drum volume) saturation can become pretty long pretty quickly. That's where recirculation shines in my opinion.
Given that Haier does not use recirculation at all (besides their new compact heat pump combo in the EU apparently?!?) I was not surprised.
Basically, why add a pump and the controls if - given it's a combo - cycle times don't really matter since drying is the longer action anyway AND you don't stuff the drum anyway.
A washer dryer the way it's used is really the one place where IMO it matters less.
Also, as far as I have seen, Haier does not really skimp on water usage in their FLs.
There should be enough cycles makeing up for the lack of recirc with sheer water volume.
Recall reading something online many years ago now that stated when water levels for H-axis washers go below certain level then recirculation pumps almost become mandatory. Those systems help saturate/move what might be a comparatively small amount of water through wash.
I bought a machine with a recirculating pump (2009 Zanussi "Jetsystem") because my previous machine, which was a right lemon, struggled to get the washing wet without help.
It certainly gets the washing wet quicker than any of my previous machines, including ones that used a lot more water, and does a better job at washing bulky items. I've also never had any specks of detergent residue left on clothing with this machine. I would think it must help with washing and it does seem to help with rinsing. I would be reluctant to buy a modern low water usage machine without one.
Still can't see the original post by combo, I'm guessing.
But ELux has a third pump (calld OkoMix over here) to pre-dissolve detergent.
So Samsung machines have recirculation, so those have 3 pumps as well (drain, recirc, EcoBubble).
The third pump just pumps the water around in circles in the sump to mix detergents etc.
I don't think so.
ÖkoMix was described by Electrolux sometimes as a "valve", other times as a "technology" but always quite ambiguously; in my modest opinion, it is just one of the many features that Electrolux claims but do not have (I have seen a few).
It is true that this video seems to show the existence of a third pump, but curiously enough it is never stated that such a pump exists:
Below is the diagram of a top of the line Electrolux washing machine ("Electrical Equipment" section, see https://shop.electrolux.co.uk/search?q=:relevance:pnc:91453340500):
- number 6 is the drain pump (see https://shop.electrolux.co.uk/laund...ain-pump-with-thermal-cut-out/p/8583792418029)
- number 6A is the recirculation pump (see https://shop.electrolux.co.uk/laund...hine-recirculation-pump-assembly/p/1325100517).
The third pump is missing, and having owned some Electrolux washing machines, I have never thought there was a third pump.
Why didn't you check for this feature before buying if it was important to you?
I still remember the recirculation spray of the whirlpool produced combination washer dryers from the 60s and always left a lasting impression on me so when LG came out with their turbo wash spraying that got my vote when it was time for me to get a new washer . From what I gather current Maytag and Whirlpool front load washers also have some form of recirculating spray but does not spray during the spins like the LG washer does
Whats wild about the FF7's water usage vs. others with recirculation is that you really aren't saving a lot of water on recirc. A standard FF7 will require about 19-21 gal/load. By comparison, using an identical load in an LG or Samsung w/ recirc uses maybe 16-18. 2-3 gallons really isn't worth it based on a $100 pump. You'll never save enough water to justify it.
Good question Turbomatic. When I was checking the list of features it listed Door/Gasket spray which I foolishly assumed meant it recirculated, that made up my mind to get it. Still not sure what it means. The only thing I can think is that water dribbles down the inside of the glass door when it is taking in water. However, I am really impressed with the performance of the washer/dryer and am glad I brought it. Love the huge capacity. Just made me wonder if the recirculation thing really makes much of a difference or is it just a gimmick. My main concern is detergent getting washed in to the sump and wasted but the washer directs detergent from the dispenser directly in to the drum over the load.
https://www.fisherpaykel.com/au/lau...er-dryer-combi-heat-pump-wd1871hg1-92302.html
Personally, I don't trust the check ball. I much rather have a recirculation pump attached to the deepest part of the sump pouring water back over the drum or clothes.
On a side note- A while back I theorized about a machine that actually pumps the recirculation water back up through a baffle piece in the back bearing bearing where the inner drum has channels in it which route the water to the paddles with holes in them. It would be so neat so see water coming out of holes in the edges of all 3 drum baffles.
Remember the Asko recirculation aswell.
That works like the Beko AquaTech and the very first few JetSystem models that recirculated to the top of tub - not directly into the drum.
Asko uses a diverter valve instead of 2 pumps.
Beko I think as well? Not sure though.
Those and the JetSystem machines of course had the "issue" that a significant amount of water pumped up would just run off the drum and only part of it would ever make it through the holes.
The designs injecting water into the paddles have similar-ish issues.
If you want a tightly sealed rotary feed for the paddles, that's a pretty expensive and reasonably delicate parts to make it quite a gamble to use.
And if you just accept some "loss" with a less tightly sealed rotary feed, again, some of the recirculated water never makes it into the laundry.
VZug basically does this, just for balancing, and I am convinced no more than half of the water ever used for balancing actually makes it into the paddles.
The standard tiday for these systems - 1-5 ports in the door seal and a separate pump in the same housing as the drain pump - appears to be a reasonable design balancing actual performance and complexity/cost.
Thank you for showing me this, I did not know such a machine existed. Good to know the concept was tried.
I wouldn't mind some water loss in the distribution system provided a big enough pump and volume make up for it such that the paddles are a hurricane of water.
The Titan by Monotub had a wash pump that sprayed water through the paddles, although its removable tubs that doubled as laundry baskets (you could buy spares in multiple colours) drew the press attention, so that feature barely got mentioned, and it also had to compete for attention against the Dyson Contrarotator. It also had a tilted drum and claimed to accommodates 40% more washing than other machines of the same size.
Very few were sold, I believe it was only available form two branches of Currys, one in Colchester, where I saw one and one in London. After Monotub went under it later sold by omega.
18267-5706f59e941511b77bc934408e180b9f.data
Thread here: https://automaticwasher.org/threads/titan.14083/
The video doesn't show the wash action
Eudora (the manufacturer known for the sub-compact washers) had it on offer, too.
And I think some South American (Mueller or something like that) had it, too.
Wouldn't be surprised that all that might have been production under license.
I wonder what the true purpose of that 5-second half-cup spin spray is? It certainly isn't meant to actually rinse any soap out. The drum decreases speed almost as soon as the spray stops. Most of it doesn't even touch the clothes.
