“SLOW FILL” Hotpoint washer
paulwash
Aug 5, 2013
88
Niagara Falls New York
Hello all .. hope all is well. Quick question my Hotpoint is filling extremely SLOW. I also hear a humming buzzing noise as it is filling slow. Water pressure in house is fine. Any ideas of what this could be? Thank you.
It sounds like it may be the inlet valve screens need to be cleaned and/or replaced.  If that doesn't work, changing the inlet valve itself should do the trick.  That humming is the solenoid on the valve.  It happens when there is insufficient water flow or the valve needs replacing.
