1938 Crane Corwith Compeer Lavatory
Ultramatic
Sep 28, 2011
41,621
New York City
I got this from a nice couple a few years ago at Newport, Rhode Island. Manufactured in November, 1938. It is complete with towel bars, legs, mounting brackets etc. The only thing missing is the pop-up drain. The lever to operate it moves from side to side, instead of the usual up and down. It is extremely heavy. This will be part of our bathroom refresh.
Beautiful sink
I remember one of those in a beautiful soft green bathroom in a house of the period. I thought that the cast in spout for the faucet was neat.
My sister's wedding reception was in Crane Cottage on Jekyll Island--lotsa plumbing fixtures, but sadly the resort, in its heyday, did not have very efficient sewage treatment and all of the goyim (it was restricted) eating the oysters would spawn a typhoid outbreak each season. It was said that the millionaires came with the first frost up north and left with the arrival of the first mosquito. The Jekyll Island Club was closed with the start of WWII because of German U boats off shore and so many captains of American Industry vulnerable to attack or kidnapping.
Nice sink, Louis!
Crane fixtures have a distinctive style that sets them apart, and seem to be of exceptional quality. I think your particular lav, the Corwith Compeer, was available for a relatively short time. The April 1940 Crane price list shows it as being discontinued; the newer Drexel style likely replaced it.
The soft green bathroom Tomturbomatic saw would have been Crane's "Pale Jade" color, a shade that was available for many years.
Louie,
I'm stating the obvious here, but it looks to me like the pop-up system has a similar mechanism to those used for bathtub drains.  Maybe there's a way to rig something based on that design for your beautiful sink.  It's a good time to start hitting the salvage yards before the winter weather hits!
I bought an American Standard sink similar to this style and era in buttery yellow at Habitat around the time they were clearing out all fixtures, dishwashers, etc. that had even a remote chance of containing lead.  I found lots of parts available on ebay and deabath.com but ended up not restoring the sink at it was too large for the small bathroom.
Your hole looks like it will take any standard pop-up.   Look for the best quality you can find, the sidewalk sale candidates will usually disappoint in short order.
https://www.ebay.com/itm/193539489057?hash=item2d0fda3d21:g:mFIAAOSwBF5e91zu
Hi Tom. Thanks for the suggestion. I am in a plumbing forum and it was suggested a good quality brass pop-up assembly would work. As I mentioned earlier, if I can't find the original Crane I'll go that route.
Louie,
I think you could use a new popup drain and attach it to the existing rod and lever system. True you wouldn’t have the Crane logo, but you would have a functioning popup drain. Just get the best one you can find with a good chrome finish. BTW, that sink is beautiful! I know it will look great in your home,
Eddie
I have a crane sink as well. House built in 1910. When the original pop up drain wore out, it got replaced with a straight drain that has a chain & rubber stopper. I couldn't find an original style drain anywhere, and a standard replacement wouldn't work as the mechanism was on the inside of the China. I eventually did find a brand new correct drain, but it was around $400 at the time. Astronomical. The chain & stopper work fine, and it fits the old asthetic of the sink.
Very nice sink Jon. But I would prefer for it to be as close to the original as possible. I ordered a pop-up assembly that should work with a little adjusting.
[this post was last edited: 10/17/2021-20:15]
I decided to do some maintenance since the sink is not installed yet. What quality, all solid brass. Apparently Newport has some serious calcium issues in their potable water.  The bibb washers are hard as a rock. I ordered 4 new replacements from DEA.
Boy, I've got more balls up in the air than a division of paratroopers.
Surprisingly, CLR warned against using on brass. So tried vinegar instead. Worked well. Still a few flecks of mineral deposits here and there. New bibb has been installed.
<script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Louie I wondered how you would replace the grommet for the popup drain lever. You know, I’ve seen grommets similar to the original one that are used for between the bottom of the sink and the popup drain. They are really large washers. If the one you are planning to use doesn’t work perhaps you can locate one of these other one. But I think you can make the one you’re planning to use work out. As they say, necessity is the mother of invention. Good luck!
I found one of the kind if gaskets I was referring to on the Home Depot website. Here is the link:
https://www.homedepot.com/p/Delta-Bathroom-Sink-Pop-up-Drain-Assembly-Gasket-RP6142/203725347
HTH
Eddie
Working on the hot water valve. But it's frozen in tight. Trying some Free All. The gasket between the valve and the body of the sink has disintegrated. Once again DEA to the rescue, but boy they're not cheap.
The hot water valve stem finally came out and it was far worse condition than the cold water one. It had a very thick deposit of dissolved minerals. I used CLR anyway with a wire brush attachment. Bright and shiny now. Now the nuts holding the valve body to the sink are frozen solid. Currently soaking in Free All.
I found yet another washer that would need to be replaced. This one goes between the stem and the valve body.
