Re Fluid Torque
On my 53 Imperial, you had 2 gearshift positions, low range and high range, low was where second would be on a regular column shift, high was where high would be, reverse and neutral were in their normal positions. each range had 2 speeds, for a total of 4 gear ratios, you pushed in the clutch and selected either low or high range, and let out the clutch, then shifting between the 2 speeds , 1 and 2 or 3 and 4 was controlled by letting off the accelerator, with the hemi, you hardly ever needed to use the low unless you were going to race or something, 1st was almost a granny gear, the funny thing was, if you took off in low range and opened it up, it was wound out at about 35....if you held it wide open and barely bumped the clutch, it would power shift into second and bark the tires, I learned this from a guy I worked with with who said his dads Desoto did the same thing, dumb me had to find out, and it really would!!To shift between low range and high range ,you used the clutch in the conventional way, great system and darn near indestructible.
