fridgenut
Questions about grounding...
The safest way to go about grounding an appliance is to ground it and plug it into a GFCI outlet. That way if the case ever were to become live the circuit would be cut off immediately, even for a small leak. I personally don't think there is much of a risk in leaving these appliances ungrounded but it is always good to be safe. Just don't do what one person on the fridge forum did and drill a hole through the condenser plate to ground it. That will release the dragons breath.
Speaking of SO2 systems, they do have oil in them. Plain old mineral oil just like R12 uses. In fact, this particular style of compressor has an automotive style oil pump which puts out 2 quarts of oil per minute! I believe the capacity of the sump is about 2 quarts as well. Lots of oil and lots of oil movement along with a very robust and balanced design are the keys to the longevity of these compressors.
Travis is right, R12 won't work. It is too dense and will put too much of a strain on the compressor. Some of these units were modified by GE to use R12 by destroking the piston travel to lessen the burden. That is where the confusion comes in. R152a which is commonly found in some brands of air duster seems to work great as a replacement. One of the forum members has had good luck with it.
