westytoploader
- Joined
- Sep 4, 2004
- Messages
- 4,485
This weekend I pulled the 101P AMP back out to replace the leaky fill flume hose and noticed that the oil clutch had been leaking as well. Per Greg's advice, I siliconed the rubber stopper on the clutch, and that seems to have solved it! For some reason it started to occasionally clickety-clack again when trying to shift into spin, so I also cleaned the spin collar with WD-40 as suggested in the other thread. The collar does move quite freely; I watched it shift into spin and the noise was caused by the collar bouncing up and down slightly (within the limit of the stop bolt) before locking into place. I'm not sure exactly why this is happening but it spins after 1-3 clicks and doesn't do this every time. Before, it was clicking simply because the collar wasn't dropping down fast enough, but now it is. I'll be monitoring this closely and have the bottle of oil nearby in the future; could be because the machine just needs to be used...after all, it did sit for 40+ years!
The machine is now installed back in the Studio and washing away again with no leaks! I ran two loads through today (towels and sheets) and plan to do more tomorrow...that Gyrafoam action is very powerful, makes for some great waves, and is definitely fun to watch! Not to mention, of course, this machine behaves and sounds completely different than your normal Maytag! Gotta love that solid/perforated tub and the direct shift into spin...
The pictures of the towel load are linked here. Here's how it looks now!
--Austin
http://www.automaticwasher.org/cgi-...OPLOADER.jpg&dir=/COLLECTIONS/WESTYTOPLOADER/
--Austin
