Part Two - the little things
So, it's been several days since my initial post. Time to get at it before this is lost in the wind!
With everything apart and cleaned it was time to tend to a few of the little things before putting the transmission back together.
First on the list was swapping out the 5431073 pump seal. The old seal was shot and showed signs of water seeping past.
Frigidaire offered this handy tool (Robinair 12472) to press out the old seal and install the new. I used some Permatex Number 2 sealer on the hard surfaces, as well as the paper gasket included with the seal. I did end up having to coat the inside of the pump housing with some RTV, post seal install, due to some of the No. 2 sealer seeping around the seal as my thought was I wanted it to seal around the crumbled surface of the housing. If I were to do it again I would have used a much smaller amount of RTV or The Right Stuff along the flange of the seal and smoothed it out over the housing with my finger.[this post was last edited: 8/23/2021-21:16]
