Next up was swapping out the original shielded bearings within the two drive pulleys. The bearings could be removed with a set of sockets and a soft mallet, or even a press, but I found that the seal remover/installer tool for the pump seal worked perfectly for this task. The pulleys have a shoulder machined on one side where the bearing sits against, make sure to drive them out on the opposite side.
The measurements for these bearings are in inches - 0.5 in Bore Dia., 1.125 in Outside Dia (thanks, Bud!), bearing number 1616 2RS PRX, Grainger 35JC45. I suspect the bearing within the bottom of the motor housing is the same size but I was unable to get the Delco installed collar off the motor to swap the bearing out.
The manual provides instruction for installing the pulleys on the motor shaft. After the initial spacer is installed, put a dab of red Loctite on the shaft and slide the larger of the two pulleys (drive) up against the spacer. Next, the helix/key is installed along with the clutch. the manual indicates that there is no specific direction the helix needs to be placed on the shaft. Lastly, the smaller of the two pulleys (agitate) is installed with a dab of red Loctite, as well.
