1968 Whirlpool imperial outer tub leaking
68imperial
Active member
Nov 27, 2005
39
I just aquired a copper color 1968 whirlpool imperial washer and dryer set. The washer needs a new outter tub seal and the 4 tub bolts. Their is a slight rusted section on the bottom of the outter tub. i was wondering if a water proof glue would fix this little problem or will i have to search for a replacement tub. Tom
If the rust hole is near a bolt hole, There is a replacement bolt kit with extra large rubber washers. "SealAll" sealant works well for small holes. Could also use plumbers epoxy.
Hi everybody Thank you for the advice. I will try that and see how it works. I will try to load pictures if i can figure out how to get them to load up. thanks Tom
Whirlpool success
Hi Everyone I was able to fix the leak and all is well. The machine is back in service. This is an excellent site and i want to say thank you to everyone that was able to help me out. Tom
Re: Inquiring or Wondering Minds:
Hi! 68IMPERIAL, would like to know which suggested way of trying to do your Repair was your decision, that worked for you?
Your WP Washer should give you a lot of years of Happy "Sudz-Cake" Washing, besides the Fun of watching it operate.
Congratulations on your successful attempt to save another Vintage Washer and giving it more life again.
Peace and Holiday Cheer, Steve
SactoTeddyBear...
Repair method
HI The repair method I used was to replace the tub bolts, used an epoxy sealant to seal the small rust hole in the outer tub,and also I replaced the center tub gasket just to be on the safe side. This is a really impressive washer. Thank you for the inquiry.
