1974 Kenmore “Green Beast” Rebuild
jons1077
Jun 25, 2014
486
Vancouver, Washington, USA
Just starting to dive into this ‘74 Kenmore washer. The previous owner cited a faulty wigwag as the reason for pulling it from service and I really wish that was the case. The actual issue is a badly corroded center post that began leaking heavily. That got the belt wet and then things don’t work too well.
This is a very clean machine for the most part. What shocked me was opening up the top and finding a plastic outer tub! Of course I immediately sent some snapshots to John L. Apparently Whirlpool trialed plastic tubs for a bit only to go back to metal outer tubs again. Apparently that makes this machine a rare survivor of the first plastic tub models to be utilized.
I only hope I can figure out the center post dilemma because this is definitely a machine worth saving! More to come!
I've seen a lot of WP built belt drive washer but never one with a plastic outer tub.
That plastic collar around the underside of the lid opening is also a first.
Yeah, the center post is BAD. May have to get a doner deck.
Maybe call Sears Parts and find out how much a new one is. LOL.
That’s really cool Jon. I’ve been working on a 71 model for way too long. It has the plastic outer tub and the center post was rotten. It’s since been replaced with a schedule 80 stainless center post and I just need to put the machine back together. That is a great set you saved and I hope you are able to fix it.
Whirlpool belt drive washers with plastic outer tub
Whirlpool built a limited number of these machines in the early 70s they were considering switching to plastic outer tubs as they would be more durable than the steel tubs that often leaked or rusted.
The energy crisis of the 70s when oil got so expensive is the reason they cited for not continuing with this project it was much cheaper to make the steel outer tubs,
The plastic used in these early 70s machines appears very similar to what they used ultimately in the direct drive washer’s it is not fiberglass or pure nylon.
The plastic outer tubs and direct drive washers increase the durability of the machine and longevity of it considerably you almost never see a bad plastic outer tub.
John
Bad news…
Got the transmission out and, as suspected, lots of rust inside the center post. Hopefully my donor machine will have a slightly better one. The baseplate is beautifully clean so kind of sad this happened. Under normal circumstances, this machine would be trashed but I’ll get it fixed somehow.
To remove the plastic outer tub, I took a rubber mallet and taped the little plastic tips and that seemed to do the trick. I’ll cut the top lip of the tub seal and carefully remove the outer tub so I don’t damage it. This will be another transmission rebuild as water leaked into it.
Jon, how great that you stumbled upon a fabled plastic tub belt drive! I agree that this is absolutely worthy of restoration and finding a good donor center post snd base plate will be worth the effort.
Ben
Center post death
This is the reason I did not continue working on my kenmore "frog-eye" washer i bought from northwesty. I have everett steel nearby that has steel tubes of almost any size, got a welder and a lathe too so I should be able to fix it, and make new bushings for it, eventually, but I just need any working washer right now so the westy front loader with its bad rear bearing is getting fixed first.
Tub removal
This is only my third Whirlpool belt drive to rebuild and think this tub was the hardest to remove. Unfortunately a hairline crack formed during this process but I should be able to repair it. I’ve contacted a local metal machining company to see about replacing the center post. If I can find the exact pipe for size and they can get it welded exactly perpendicular then it would be great to save this beautiful baseplate. I have yet to tear apart my 1970 800 washer. It may end up being a donor for the baseplate if it’s not too rusted.
Original baseplate
Hey there, John!
I am really sorry to read about the rotten center post on this beautiful machine. I had originally been thinking that this machine didn’t deserve the title of beast, but unfortunately, now it just might. Maybe we should call this the green beast two?
I noticed in one of your other pictures, and confirmed tonight, that this original base plate seems to have a large capacity style tub outlet hose. I noticed it also seems to have a couple subtle differences from a corresponding base plate that goes with a metal tub. This, unfortunately, may make some complications in parts interchangeability with a baseplate for metal tubs.
I wish you good luck in getting a new center post pressed into place!!
Gordon
I believe it’s worth it. I’ve had 3 made but haven’t put them back together so I’m not much help with information. One of them is a 1971 kenmore 70 with the plastic outer tub just like yours. I’m ashamed to say that one has probably been apart for 2 years now. Best of luck with yours.
