Been a while since I last posted. Funny how careers can do that on occasion. Anywho...
Last year I picked up this Dispensall for around $25. It wasn't in the worst condition so I figured it could be a fun machine to play around with. Functionality of this machine was fine with the exception of some huge gaping holes in the outer tub due to rust. I disassembled the machine and the holes patched up nicely. It seals great and not a drop anywhere.
The current MAIN issue now is the timer. The teeth are worn down so I needed to replace the knob and plate(?, the disk that the knob locks into and indicates your selection of cycle). In my attempt to do this repair I inadvertently removed a couple of screws I really shouldn't have and my timer came apart. As many of you may know those little contacts inside the timer just fall right out and who knows where they go when that happens. I tried replacing them the best I could but the timer doesn't work. It fills, it spins but when it is supposed to agitate it blows a fuse.
Maybe one of you who is a timer expert could either share with me how to properly repair this timer OR perhaps you know of a good timer repair person that I could send it to? Once the timer is fixed this machine should run 100%.
I've attached photos. Of course any help and guidance is appreciated!
Jon
Jon
