1978 Norge bearings? Seal?
Bearings
Storms knocked out phone and web 2 weeks ago and ATT sucks for repairs, but here's the latest:
I took the hub with the old bearing to 3 auto mechanics. 2 said they wouldn't try out of fear of breaking the pot metal, they are used to hardened steel for auto brakes/rotors. Third guy said 50/50 chance, I said try it. He successfully swapped out the bearing, and also drilled out the 2 broken bolts. Yippee!!!!!
I wire brushed all over the place, got all old cork off the thing. You can see there are 2 weep holes, and that the very innermost ring, just above the retaining ring, has some dings in it, not a perfect surface.
Robert 1964, Mark 1978
The 2 top pics are stoolen from WebMaster Robert's 1964 rebuild of a Norge, referenced above. Bottom 2 shots are mine. I trust Robert's assembly and will get some good epoxy/sealant over the wekend, but I don't understand it all.  If I epoxy that ridge where the copper/brass cone sits( innermost blue epoxy) , it will prevent water inside the cone from getting to those weep holes. Also, shouldn't I keep the weep holes open, very careful with epoxy?
I will definitely epoxy the outboard edges per Robert's photos, but am asking for an explanation of how this cone works, what its purpose is.
Ceramic seal
I am feeling extremely confident since all the origianl cast parts are re-usable, and the seals are all brand new. This is the spin tub hub with the upper ceramic seal removed. My strong guess is epoxy exerywhere the seal seats in it? I know to keep the mating ceramic faces spotlessly clean.
Also, the closer I get to re-assembly, it is seeming smarter and smarter to install both these hubs on the tranny/shaft/post before I re-install the 2 tubs. That way I can see everything, epoxy everything, etc. How tightly do I mate these surfaces, how much compression on that spring/ceramic/mating surface?
last pic for now
This pic shows more, no epoxy yet. Won't epoxy seal off the outer edge of this cone, keeping any lost water inside on the bearings?
I want to do all this RIGHT and ONCE, and I appreciate all advice. I have meant to document and post all, but AT&T SUCKS!!!!!!!!!!!! I lost 3 days of work to waiting for them to no-show already. Day 4 is rescheduled for Monday, wish me luck.
Dumb question:  Does this cone form a grease cup around the shaft? Am I to fill it with White Litium grease? Is that the purpose?
more
No epoxy yet, but just fiiting things together, it seems like I am quite wrong above. The brass/copper cone is pictured wrong. It should be like a bowl, not a hat, so the center of the spin hub sits down against it, right on top of the bearing, and therefore the 2 entire hubs and seals all meat properly for compression sealing. Agreed?Sort of seems like then any stray water drops would be spun up and out to those weep holes. Proper assembly therefore will compress those ceramic/spring seals, I can now see how it properly works.
Also, various pics way up the chain show some white plastic gasketing, and some cork. With the mismatch between various items from a  different Norge, I was able to cut both spin tub gaskets to fit, and will epoxy/RTV/seal both sides during assembly. However, I will have to cut new ones for the outer tub, both sides. Where does one get thin sheet cork? All will have epoxy, but I want the cork also.  During dissassembly of the 35 year old machine, everything looked like cork, not whatever that plastic foam sheet is.
Paging Robert and John Combo
Guys---Pros---Read a bit above and compare that brass cone ring. Roberts pics show it up, like a hat or a tepee letting out smoke. So far, with no epoxy or permanent installation, my "fit-together" strongly suggests that it should be down like a bowl or funnel. Then the inner tub flange screws down and seats immediately against the innermost brass flat spot, which is pressing directly on to the bearing itself.
Please check photos---I unfortunately have storm/tornado/ATT&T troubles and can't log on at home--but will checkback before final assembly------
Horrible photo here, but it shows my belief that the center of the ring is down directly against the bearing, not up.
I bet you one thing!
You aint never had a washer that will wash a filth big load clean as that thing will!!John may be right, he knows about a million times more about washers than I do, but I still wouldnt let that brake stop a spinning load of clothes, just my opinion.
Rusty hub/bearing
If you haven't gotten the rusty bearing out of the hub, I would go to an auto parts store or hardware store and pick up some Evapo-Rust. I'll bet if you soak that hub/bearing for a few days in Evapo-Rust, it will dissolve the rust and make it easier to remove the snap ring and bearing. I have used it with great results in the past, but it works best if you keep the rusty part completely submerged in the solution.
http://www.evapo-rust.com/
Better pics
John--Here's some better pics----and I did a complete assembly this morn---this ring HAS to go down like a bowl, or the mating ceramic/graphite faces are 1/2" apart. First pic is the underside of the spin tub hub. The seal isn't yet pressed in, take note of the length of the overall shaft
next
here's the old versus new ring. Old would have ended 1/2 way across the bearing face. New one --like a hat fits sort of snug against the shaft about a half inch up from the bearing. Or, installed down like a bowl, sits on the innermost bearing horizontal ring, right against the shaft
assembly
heres the assembled shaft, cone installed down against the bearing, all hubs and spanner nuts fitting perfectly. Cone up would leave a 1/2 inch gap between mating surfaces, would not allow spanner nut far enough down shaft to screw on. I see no alternative
