troubles
6 holes versus 4. My outer tub and original support is a 4 hole unit. New one is six. I'd sure rather use the new one, but I doubt like hell I should drill new holes in the outer tub. If it was only metal, I would in a second, but porcelain???? 6 holes at 60 degree spacing versus 4 holes at 90 degrees means only two match up. I will gladly listen to any suggestions, and many thanks.
Also----after breaking one self-tapping screw in the old 4 hole support, I one-at-a-time heated the bolts, rubber mallet smacked them tighter a few times, then looser, back and forth. 2 came out marvelously. So that's a new trick from you guys, thank you. But the final one snapped quite easily. So my original 4 hole tub support has 2 screws out, 2 broken down in the holes. Frankly, if I drill them out, there's quite a bit of clearance beneath the hub to install thru-bolts, washers and nuts on the bottom.
