sesteve
Well done again. As they say perseverance pays off - apparently and you have certainly persevered with this one.
I'm a bit surprised that it is noisy on the wash as generally the noisiest part is the draining but having said that they all sound slightly different to each other. The noise on my 1509 lessoned quite a bit once I'd sorted out the clutch shoes as one of them had jammed in position and now it makes the same amount of noise for wash and spin.
Is the leak coming from the dreaded support tube? I think that the debor glue that you used to put the counterface in may be causing the problem as it looks from the photos like it could interfere with the movement of the face seal and allow the seals to part when they are moving. Could be worth clearing that out and seeing if that works. Otherwise I think I'm out of suggestions.
Hope you get it sorted
S
S
